nadthomas
- Joined
- Dec 1, 2017
- Posts
- 158
- Reaction score
- 177
I instaled ARP studs. P/N 434-1301.
Problem solved forever.
View media item 27143View media item 27137
That bad boys are over $100 for the set.
That bad boys are over $100 for the set.![]()
Slowly picking away at this thing. I still need to order all the parts to actually freshen up this motor, and get it put back together. I'm not sure if I have been legitimately too busy to get the order in, or if I just don't want to spend the $1600.
I did pull the valve covers, front cover, and oil pan this past weekend. The rocker arms and springs look good, tight, no sludge, or random needle bearings floating around. Just some staining from the previous owner using a synthetic blend. The timing chain and tensioner looked great. Zero slack in the chain, and the tensioners had no signs of wear. So, I'm going to leave all of that along with the camshaft alone, and just replace the oil pump, VVT Oil Control Valve(bolt looking thing), Magnetic Actuator, and Camshaft Position Sensor. The oil pan was a bit of a different store. There was a good 1/4" of dirt/sludge in the very bottom of it. I'm really surprised that not more it comes out when you drain the oil. I cleaned everything up with a wire brush and carb cleaner, and new gaskets will go on everything before I button it back up. I wasn't going for perfection, just cleaner.
I also rolled the front half out of the garage so I could clean all of the grease out of engine bay. I wiped down all of the wiring harness, and sprayed the frame rails and cross bracing with oven cleaner. I'm not sure if this was a great idea. The finish on these parts appears to be different. The oven cleaner made it very soft, to the point that I took it back to bare metal. So, now I'm working on taking it all back to bare metal, and spaying it with Eastwood textured black rust encapsulation paint. At least its clean now.
I would replace the oil pressure relief valve in the oil pan while it's off...
https://www.gmpartsdirect.com/oem-parts/gm-relief-valve-12608835
https://www.amazon.com/12608835-VALVE-OIL-PRESS-RLF/dp/B015NE7VWW
Also install the shield if it doesn't already have one on it.
Cheap insurance so you don't have to possibly drop the pan later.
...flip flops are not proper safety gear when welding.![]()
