- Joined
- Jul 31, 2011
- Posts
- 5,125
- Reaction score
- 161
this truck is really starting to piss me off!! everytime i change somthing on it two more things pop up currently :
--headliner -GONE
--culster- SHOT
--electrical problems OUT OF THE YING YANG power windows deathly slow to roll down an up , door locks not operational , power mirrors not operational dimmer switch blows fuse everytime its moved , abs light and actuation randomly comes on , corner lights not operational ,rear hatch switch doesnt work
--passenger winsheild sprayer doesnt spray (took entire cowl apart thought i fixed it with a needle doesnt work again)
--A/C doesnt blow cold at all which that doesnt make a **** because the blower appears to only work on low
--driver side mirror about to fall off for the 3rd godamn time
--rear seal allows a pond to grow in the cargo compartment
-- pass door needs to be pushed open (either handle spring or door pins )
--dash starting to crack all up
-- im pretty sure any and all bushings need replacing at this point all are cracked up an dry
recently replaced within last six months
--radiator and a/c condensor
--front grille and headlights,bumper and corners
--starter
--ball joints pitman arm and idler arm
--shocks
--led in dash
--both front hubs (4th pair in two years)
--tune up
--left front window along with window master switch
--headlight dome dimmer switch
--taillights (i had an aqaurium in both)
-- all u-joints
starting to get fustrated i think the electrical system needs a complete OVERHAUL any one do this yet??
i thought id share my problems incase any of you are dealing with the same issues i understand this vehicle is close too a 15 years old an shit like this must be expected but its gotta give me a break, if not ima have to park it until funds are available
also thought about a new tahoe or preferably a yukon
--headliner -GONE
--culster- SHOT
--starter
--shocks
--led in dash
--tune up
-- all u-joints
