New alternator, flickering lights
The amp spec is usually stamped on the alternator housing. And the 145a usually has the dark gap between the case halves, while the 105a does not. 145a shown:
T
Timc9516
Well guys the holidays hit and it was 17 degrees feels like 0 so I'm gonna try Saturday morning ill let you know what happens
GMT800 SUV/Trucks
Yea, I know what you mean. Cold spell went thru here today. Down to 40 degrees. Looking forward to normal, rain and 45 at least.
GMT800 SUV/Trucks
Glad it got taken care of by them. It's always good when they stand behind the product with no grief to customer.
Did you ever figure out if is 105 amp or 145 amp?
Well I went to advance today and swapped the alternator and it seems to have fixed it. Thank you guys for the help
Thank you for getting back to us with your resolution. Our collective knowledge base is increased.
bladenbullet
what you were experiencing is called diode ripple...an alternating current leak through the diodes...with a description of your concern the alternator should have been exchanged the first time you brought it in...
the diodes change alternating current to direct current to operate your vehicle...a failing diode will leak a "ripple" on the dc current and can screw up a lot of things...many transmission concerns are alternator related due to the electronic controls...
matty40
