new Carven TR muffler/Performance Issues
HD_LS
Did they do any welding, when they installed the muffler? Welding can cause stray currents & voltages that can damage one of the modules.
E
Em Vee
Yes they welded the muffler on. I will check under there and see if they might have burnt any wires or anything.
I am also thinking the steel wheels are making it slouchy too. They are 42 pounds each according to Pro Comp. Thats HEAVY.
Sam Harris
Texas
True, but your issue sounds bigger than heavy wheels.
Re-reading your post, you also installed new wires and plugs at the same time? Or were you just listing what had been done since you purchased it?
If those were done at the same time, I’d definitely be looking into the plugs and wires, making sure they’re as they should be. I had ARH longtubes installed at a very reputable shop, and at the same time, he did ARP bolts in the headers and plugs and wires since he was there. But dude is an exhaust guy, not a mechanic.. I had 3 or 4 plugs actually loose in the holes. Wires were installed ok though. Heh.
E
Em Vee
Well the car was running bad since I got the muffler installed. I got the plugs and wires done the next day because I thought maybe the plugs and wires were old, but it still drove the same even after.
E
Em Vee
Sam Harris
Texas
Hey guys, thank you all for your input. I found the problem. Clogged Catalytic converter. Problem is now fixed.
Glad to hear it was identified. Interesting that this wasn’t identified until after the muffler install.. :confused:
E
Em Vee
according to the muffler shop it became more noticable with the new muffler because of the change in flow. Going from a really big 22" muffler to a small 14" muffler caused a change in flow especially in the low rpm range. Now that the catalytic converter was changed it feels like a new car again. Im just happy that it drives better.
Garage2010
