Hey, I’m Dave and recently purchased a 2012 suburban LT with 5.3, 4x4, with 50,000 miles on it. Pretty excited to get to know it better and figure out good reliable upgrades for it. I put good floor mats in it and tinted windows . Trying to figure what I need to do to make and keep this a reliable vehicle for many years and miles to come. I’ll snap some pictures tm. Im from Southwest Ohio. Thanks for all the info !
Nice rig Dave and welcome. That's a great price for those few miles.
Crawl underneath and examine her for rust. Get the spare tire hoist operating. Put the truck on a 50K at most service interval and start by changing all the driveline fluids. Find out what kind of oil she was using before you switch it over to your favorite flavor lest any crud break loose and gum up the works inside. If it has a rear air compressor, verify that it is working and working properly. Also check the rear air shocks for leaks. Eight years, regardless of miles, is when it's usually time to replace them. (Z55/G69)
If you plan to tow with it, find out if it has the single speed transfer case which would mean 3.08 (GU4) gears and a 5K or so towing limit. 3.42 (GU6) gears will allow for 8K pounds with a WD hitch and comes with 2-speed TC (NQH). Does it have an integrated trailer brake controller (JL1) on the left knee bolster under the lights and TC actuator? No matter, if not, there is wiring under the dash for an aftermarket controller. There are two wires under the dash still wrapped up until you decide to tow with it.
Consider strongly a bi-directional scan tool like the Tech-2 at some point to diagnose and help solve problems. More important than a wrench. There's also Bluetooth or WIFI adapters that talk to apps on your phone that work too, just not as in depth. Read your owner's manual cover to cover.
Consider also a tune, not just of the engine but the transmission too. Such will make it more driveable and durable. BlackBear Performance.
You can send GM an email and they will respond with a breakdown of what all those codes mean on that sheet in your glovebox. This is your RPO Sheet and tells you how your truck is optioned.
Does yours happen to have the LMG or LC9 engine? I think it should be the latter.
