All fuses check out as good and the starter relay is at least clicking. I am going to rug something to check to see if that relay is sending power out. Does anybody have a starter circuit waiting diagram or could what color and where the neutral saftey switch is?
the neutral safety switch is attached to the transmission right where the shift cable connects, there plastic and thin metal and usually kind of fragile feeling, if the switch is out of sync or worn out that could be why it wont start it's a safety device so you don't accidentally start it in gear, you can get under there and take a look at it, it has a electrical connector and a couple bolts holding it on if you have a helper you can have them move the shifter up and down and you can see how it moves back and forth once it is in park you can take the cable off and see if it clicks into place by hand or if it feels like it is in the right position just remember the position it was in before you disconnect it because if you get it out whack then you will have to buy a new one or figure out the right position (prnd123), if you buy a new one they come locked into place with a little metal clip so you can just slap it on and connect the cable and hopefully be in the right position. there usually not very pricey for a aftermarket one I haven't bought one in a while but I'm thinking around $35-40.00
sometimes the wires get a bad connection at the harness so take a close look at them maybe jiggle them around and then try to start it again.
if you take it off there usually on the shaft kind of tight so just wiggle it or use a flat head screw driver to kind of get a little leverage and then it will just slide off
