New Tahoe stuck 4wd high
K
KenC
That would be great if you could,I can usually figure anything out on my own but with limited abilities to diagnose it I've been having a hard time.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
i attached a nice little packet of files for you. if you need mechanical data or troubleshooting sheets for specific's dtc let me know.
  • NV-246 Description of operation and electrical diagrams.pdf
K
KenC
Couldn't get file to open,can you double check link please?
K
KenC
Had shop check it out and turns out transfer case is shot,I'm assuming PO drive it in 4wd cause motor went bad and killed it
SunlitComet
OBS Jedi-Do Good
what failed exactly? you did say it was working in 4hi? you also mentioned the neutral setting. was the tranny itself in neutral when the t-case was shifting?
K
KenC
The shaft for t case is real hard to turn,that's why motor burnt up and it popped fuse when I installed new motor.shop is very reputable we found a used t-case for $400 and labor $90 so I'm probably just going to have him fix it for me and I'll pull old t case apart to see exactly what failed
daddy g
