New To Forum, Found Denali Powerbuy...
D is for DENALI
D is for DENALI
it's an oe ac Delco sensor and there is a mesh screen on the sensor...
and the main reason for changing the cats is because they are stock, had them temp checked and a muffler shop said I should be replacing them soon according to the laser temp gauge they used..
I bought this with 175 k, and I've put on almost 16k in 9 months, now im at 191k on stock cats.. I've changed everything else on this truck why the f not, right?!?!?! hahhahah
D is for DENALI
D is for DENALI
https://stlouis.craigslist.org/pts/d/2001-gmc-denali-for-parts/6308815336.html
I found this ad, same color as mine!!! now I can get the door handle assembly that matchs... what else should I grab while in there?
what's a good price for the whole thing?
maybe rip exhaust and cats off? wheels look good too, maybe even take out the rear entertainment if it has it...
was hoping the grill was there so I could replace the broken one on mine...
eta-- so I got in touch with him, and asked him what a fair price for the whole vehicle would be.. he said $450... so now he is sending me more pics, should I jump on this??? help!!!!!! hahaha
adventurenali92
Big Bear Lake, ca
Yes that looks like a 2002 model. The rear entertainment will not work for yours. But door handles are the same. Just about all exterior body stuff will be the same.
It's actually titled as an 01. Count the 8the digit from the right, it's a 1, meaning it's an 01.
D is for DENALI
D is for DENALI
well I offered him $200 for the DENALI, and he said no... i asked how much for a door handle assembly, right headlight, driver window switch assembly, and the windshield... he said 125... maybe if I lived in st Louis but not plus 7 hours of total driving...
anyway, en lieu of rocket man telling me straight on the denali exhaust, im going to spend the thousand dollars I was gonna spend on a corsa, and use it for speed engineering headers and gm gaskets($300-400), install cost ($120 , 3 hours roughly), electric radiator fans(160ish), e harness(40?), and smaller alternator pulley(30?) for light dimming at low idle... that leaves mostly enough for booking a tune, or I might save up for an autocal... that will give me substantial power gains...
during all this spending madness I will most definetly be putting goodridge g stop SS brake lines on the new brakes I already installed when I bought it..
maybe when I get my tax return back I will get my exhuast... i don't want to pay $950 for 5 hp, and I don't want any drone at all, so that leaves out most exhausts, so we'll see when I get there.. I might just weld a new tip on like Beardeddenali...
I doubt you'll get the SE headers to work on a Denali. They cone with a y-pipe instead of running 2 separate pipes to the muffler, the y doesn't even usually work with a 4wd Tahoe. Just look at @Tonyrodz 's build thread. He had to remove the front driveshaft in his Tahoe due to the Y. You can't remove a driveshaft in a Denali or the transfer case will self destruct. If you want longtubes on a Denali you'll have to pony up for American Racing or Kooks unless you want to do a bunch of fab work. My AR's were $1400.
HiHoeSilver
Away!
Chicago
Are you close to Chicago? Book that tune... They are looking for more people!!!
Lewy1824
