New to me 05 PPV A/C Question
MrRock
MrRock
What's the fuse look like?
Really though this ^^^^ check it first
I will check the fuses and relays just to make sure because i am sure it could be as easy as that. I saw the lines under the truck in the rear passenger corner but i just have to make sure they are not possibly capped off or block going towards the front. Ill be in touch to advise as the weeks go on and when i have the truck on a lift.
OneofFew
Talullah Falls, Ga
did you turn the rear a/c on using the controls in the front? maybe one control panel works and the other doesn't.
MrRock
MrRock
Yes with the front controls, on the map light overhead console but it just may be that doesn’t work either. We just have to check the fuse, relay and test the controls to make sure everything has current. My initial question came to be because it was strange for me to not even hear it come on at all.
DarkBlue38
