New water pump and thermostat, now this issue.
Dannydean
Normally your temp will be 10 degrees above the thermostat. And to get it to do that your fan neededs to be reprogrammed to come on earlier.
TURNz
TURNz
Ok 187 plus 10 is pretty close to what your seeing.
Right. A mechanic friend of mine told me the same thing. 10 degrees hotter is usually normal.
Thanks everyone. Also, the last two times i drove it and checked, fluid level held steady.
Sent from my SM-G935V using Tapatalk
Dannydean
Do the temps drop a little when your at highway speeds, when your moving lots of air thru the Radiator.
jlmabiepsu
