NHTSA opens preliminary probe into more than 870,000 GM vehicles
djnice
To me it seems like the 5.3 downshifts a lot. Slight throttle and it downshifts. At 75+ it stays in 9th a lot. I figure its time spent in higher gears is making it get worse mpg.
jfoj
Different video with interesting info but it has the same thumbnail background, it is not a duplicate.
jfoj
What I do not understand is are the replacement motors "New" from the manufacturing plant or "Reman" units that have been reworked.
What is scary is even a "Reman" engine from GM is only showing at a cost of around $3700, I assume dealer/warranty pricing may even be less.
I also understand that often when starting out with a "Reman" product, assuming the GM is not buying from scrapyards or taking back failed engines, sometimes, a number of "New" parts are depolyed to fill the pipeline.
What is crazy is I am seeing other suppliers for the L87 used going for $5000 to almost $10,000!. Might be a supply and demand thing as well at the moment.
I have seen some "New" long block engines for around $7500.
I not a fan of "Reman" engines as you never know what shortcuts the supplier is taking at the workmanship as well. What parts are actually replaced on the "Reman" units, what parts are reused, what parts are machined?
Somewhere I thought I saw that GM may have artifically pushed the replacement engine prices down pretty low, but maybe I am mistaken. I can see with this large number of failures, there might be some back office price adjustment to make the "sting" feel less on the corparate level??
RG23RST
Why are you folks still bringing it up LSPI? It simply isn’t a concern on naturally aspirated engines. That was only an issue on early iterations of small displacement direct injected turbocharged engines. Even then it was primarily an issue with cheaper Asian brands.
RG23RST
Complete engines and transmissions actually haven’t gone up in price that much for years now. Some adverse with a core charge and some do not. I’d wager that’s what you’re seeing. You can get a 6.2 delivered within a few days with 4 digit mileage from a number of large recyclers but you run the risk it has defective bearings too.
jfoj
Suggest you do your homework and research. LPSI is not just on forced induction small displacement engines. The 6.2 barely runs over 1800 RPM under all but sprited conditions and maybe towing where the engine downshift or if the shift points are altered much in other driving mode.
LSPI is more a function of oil introduced into the cylinders, liquid fuel in the cylinder and higher cylinder pressures during lower RPM, high load considtions where the throttle is open over 30-40%. Also understand the vehicle being propelled is not a 3000 lb rice rocket, this engine is propelling a 6000 brick.
Coupled with running Regular grade fuel. While the spec sheet for the L87 indicated it runs on Regular fuel, this is not what the owners manuals indicate. They recommend Premium fuel.
SkyWalk3r
