NNBS Electrical Upgrade Write Up – BIG 3 and Audio (56k Warning)
RollTide2
Birmingham
Yeah I need to do this. Did you upgrade your alternator too or was the stock one enough along with the big 3?
Modded
Modded
That Guy
The stock one is enough with the big 3 for my setup. 700 watts more and I would need a new alternator.
Fearz
Houston
I run the stock with a Xs power 3400 secondary powering a Crescendo 2k and My voltage only drops at idle.
It's a few guys that run Sundown Audio 3k's around me and they run the stock alt with 3-4 nice battery's and have no problem with voltage.
RollTide2
Birmingham
Thanks guys. I was just wondering just incase I upgrade more in the future but I'm still gonna do this pretty soon.
Modded
Modded
That Guy
Amp rack mounted up with rear bracing and some Lexan.
Modded
Modded
That Guy
Modded, is your system in your sig your final until you get a new ride.
Yes it is my final one until I get the next gen Tahoe/Yukon.
It is my last mod period because I have dropped $10k into in since I got it and anything after this point would be a waste.
denalianyone
NYBlackLade08
New York
What did you do with the smaller wire that was snipped from the negative terminal? Was it just taped and left alone or reconnected?
Squirrely tahoe
