donjetman
- Joined
- Oct 22, 2018
- Posts
- 1,680
- Reaction score
- 2,960
Oil pressure doesn't create shear strength. Viscosity doesn't = lubrication.We have variable displacement oil pumps, now we need variable minimum viscosity oil.![]()
Before the oil reaches operating temp (200) our oil pumps spend a lot of time in bypass, what a waste. Engine oil is used for cooling. Oil volume will draw heat away.I'm no scientist, but I believe that if the oil were more water-like, such as 0W-20, it would require more volume and the resulting pressure to achieve the same shear strength. But, I run my stuff hard
@donjetman, have you noticed any change in your MPG since the lighter oil?
I've noticed no changes in oil pressure or mpg since switching from 5w30or40 to 0w20.
over the yrs in this Denali I've run top shelf 5w40, 5w30, and now 0w20.
I don't hot rod our L92 6.2L.
In a perfect world (winning a lottery) I would stick a stock 4.8 w/VVT in our Yuk.
