No oil pressure on start up.
Fless
Super Moderator
Elev 5,280
This. Especially with how cheap they are, they're always handy. It's been a while since I've researched, but, last I knew, it seemed that the ~20-$40 bluetooth dongles that synched with your phone were some of the best options as far as capabilities.
You could set it up, pull up the oil pressure display, hold your phone next to your gauge cluster and start the engine. If the gauge shows "0" but the PCM is reporting normal pressure, then you've found your problem.
*EDIT* I think the "Torque" app is what the cool kids are using these days.
^^ THIS. Don't look at codes, look at live data. There should be lots to see, like engine coolant temp, oil pressure, etc.
Torque Pro ($4.95 on Google Play) is the way to go with the OBD dongles.
EDIT: Torque Lite might even show oil pressure, it's free on Google Play.
Blackcar
You might want to read this article.https://www.noln.net/articles/2223-low-oil-pressure-message-locating-the-mystery-filter
richs1
richs1
Just replaced the oil pump on my 2011 Z71. Not the same issue just very low pressure(below 20). 165000 on that one. This one has 114,000 miles.
My next guess with yours was gonna be a failing/failed O-ring. It might have a slight split that could intermittently allow air in that pickup tube, which would let the oil pump lose prime.
richs1
richs1
I’m thinking that is going to be the issue, if I am dropping the oil pan on this one, I’m putting in a new pump along with the o ring
richs1
richs1
True, but you have to drop the oil pan to get it out, at least I did on my 2011 Z71
Milooo
