NO Start after Mods - Supercharger
F
Foggy
KS
OK SO THANK YOU for all the suggestions
I bypassed all the extra wiring for the TMAP to MAP, Purge Solenoid and MAF
Just hooked everything up like stock.. I had an extra New MAP sensor .. So I ran
the vacuum line from the SC intake to the stock MAP sensor.... Opened up the
bypass SC valve and kept it half open... and put stock MAF to stock harness.
Started Right Up !!!!!!!!!!!!!!!!!!!
Ran like shit though... like on 4 cylinders...
SO i got to thinking maybe the DOD lifters were being activated by "default".
So i hooked up my diablosport tuner and just did stock tune with DOD disabled..
RUNS LIKE A CHAMP !!
Well, idle and rev just a bit..
SO I'll take it real easy and drive it to dyno in the morning. And wait to
re hook up all the edelbrock electronics after they do some initial tuning to get
it started up.
Thanks Again !!
I was about to give up hope on this
F
Foggy
KS
So, stock tune, with it's AFM programming and all, but a "regular" valley cover? There's one major problem. Contributing problems:
1) New crank position sensor which has to be relearned. It would still run on the new one as part of the relearning process requires the engine to be held at 3,000 RPM (I think that's accurate).
2) MAF is reading lots of additional airflow. The PCM should be comparing this to the MAP's input which I'm guessing the TMAP is their plug-and-play solution?
If you still have the original VLOM, plug it in and see if there's any improvement. I don't see how a "delete kit" can just be a valley cover, though. AFAIK, you can either disable the system in the tune and the lifters will stay pumped up and act like normal lifters or you can delete the system by installing all normal lifters and a regular valley pan and tuning out the feature.
The entire vlom gets deleted.. Just a valley plate with the SC...
I did get it going !!!
looking at the edelbrock instructions https://edelbrock-instructions-v1.s3.amazonaws.com/edelbrock/1567.pdf 17/32; it looks like they pull the solenoids off the vlom but i guess the passage way still flows oil to keep the lifters pumped up? and it doesnt really express but im guessing that gets mounted to the supplied valley cover. either way without a tune and the vlom unplugged it will barely run
Interesting!
Yeah, it instructs to drill out some oil passages and I see why they specify to reuse the gasket. The towers are plugged off with some caps that are held in place by the cover. I'm guessing the oil passages are modified to direct pressurized oil to the AFM lifters.
Randeez straightened me out. So, in doing the gasket modding, etc. you get all 16 lifters mechanically operating like it's an 8 cylinder. But the PCM sees an AFM failure and is killing fuel to those 4 cylinders. The tune fixed this. Good thing you have that Diablo! Otherwise, you'd be towing it to the tuner.
Be sure your tuner knows you replaced the crankshaft position sensor so they'll perform a CKP relearn before tuning to optimize it.
F
Foggy
KS
Thanks for the advice on the Crank Relearn...
And Yes, I'll update this when tuning etc is done to let you all know
how it is running.
Side note: this better be worth it !! what a pita this has been.. Way more
work than just a "bolt on" project for sure.
If I had known what I know now, I would prob have just done cam and heads.
But also know that I'm addicted to boost... so ....
Yeah I had a lot of trouble when I installed my Whipple due to a missing addendum to the instructions regarding a secondary set of intake manifold gaskets which ended up forcing me to remove the whole thing and start over. Twice. And the bolts holding the blower on were almost impossible to get to. But it is worth it, you’ll see.
F
Foggy
KS
So, here's my first follow up:
Got it "tuned" and I'm not super impressed.. Although the shop was not
happy with my choice of fuel and wanted me to bring back to them after I run
at least 2 tanks of top tier fuel thru it.. They had to pull a lot of timing
352 hp and 380 torque
Although I know there are a lot of factors in place
Type of dyno, tire inflation, which gear, yada yada....
So I was hoping for more
I kinda figured with 403 stock hp = about 320 on dyno (20% loss)
that I'd be around 400 after the supercharger and headers
jrmhokie
