Norcal's Ultimate Cornering Package. Another truck done
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
no i posted it in my vendor section
WingsAA
CMFIC
Dallas, TX
Figured I'd add to this thread and confirm. I recently swapped out the rear Belltech shock relocation brackets on my 08 Suburban LTZ / Autoride with the DJM shock relocation brackets. I also added the DJM lower trailing arm relocation brackets and WOW... I really noticed a big difference with not only the suspension control in while cornering but the stability under straight-line acceleration at WOT. It's tight. I highly recommend you have Tony send you the DJM rear hardware kit if you're running the 2-3/4 kit. On a side note, I didn't have to use the shorter DJM sway bar end links as I have hotchkis front and rear sways and the rear end links are already shorter and the sway bar is designed in such a manner that I couldn't get the end links to work anyhow so I just kept the hotchkis end links and it's working well as designed.
One last note regarding solving the GM lean on the Suburban with Autoride and Tony's 2-3/4 kit. During swapping to the DJM rear cornering kit, I tested out removing the right rear spacer while leaving the driver rear spacer installed... I'll say no more that if you have a Suburban you must so this NOW!!! Truck is level and handles amazingly!
I think that's enough typing for now
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Im waiting for some more pics another customer just finished his up tonight
LILC509
Is the DJM rear kit the same for autoride and non-autoride?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
yes but just a heads up on 28s when lowering pass side tire sticks out more thats why I would get the spohn panhard bar to push it back under the truck its $135 shipped
