OBX longtube 4x4 fitment
SCHUBS
if you mean thorleys tri-y's you got installed pics? want to see the look at least cause i still can not install mine yet. need some comfort in the meantime.
I will see if i can find any pictures of them, i know i have a few pictures from the engine compartment looking down at them, but i sold the truck 4 years ago.
what did you want to see?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
anything of them.
---------- Post added at 05:01 PM ---------- Previous post was at 05:01 PM ----------
install from above and below if you got any.
SCHUBS
This was the only picture i could find. This is not show crome. after a while of heating up, the crome got a blue and purple color to them looked pretty cool, never had any problem with the finish, great header. i would put them on my truck but i bought it with shorties on it.
SunlitComet
OBS Jedi-Do Good
Cool i have the same non-show chrome finish. Now I will know what they will eventually look like I will get pics when mine are done. If you ever find any more let me know.
milehighaz
Tucson, Arizona
why would you keep the cats but delete the rear o2 sensors, that makes no sense if you have the cats in then the rear o2 sensors will not throw a code. the only time you would want to delete the rear o2 sensors is when you remove the cats.
and you dont have to tune them out you can modify the O2 sensor to belive the cats are working.
this works on the trucks too
http://paladinmicro.com/MustangMILEliminator.htm
Wow...let me get this straight and please excuse my ignorance....I can remove my cats, modify my rear o2 sensors per this link, install them in the tubes and emissions will never know I don't have cats??
96redsport
Altoona, Pa.
They also have O2 simulators you can plug in to replace the O2 sensor altogether however this runs into a legal issue depending where you live...
SCHUBS
cancel that this does not work for the trucks, it kept my check engine light off, no DTC's but my truck would not run the heated O2 sensor test and the catalyst efficiancy test. i am now going to have to get my truck tuned unless someone else has a way around it
SCHUBS
If you know where to find them let me know, but from what i heard, the guy that use to make them got pinched and i looking at jail time, federal offense. that is what is on my truck now is the plug-ins
I tried the link that i posted on my truck did not work, it worked for my old 98 mustang though. i am guessing might need different resistors or something, i am going to look into it.
Bnels82
