Ponchonutty
OK so say that I am driving for a while and apply the brakes, the brakes are soft and the pedal feels like it will go to the floor. If I pump the brakes I have a firm pedal. There is not any pulling either direction nor are there any leaks. If I pump the brakes and hold the brakes down, there is no further travel. The pedal stays in the original location. It does not continue to go to the floor. I am due for a front brake change but other than that everything else is fine. I am at a loss as to what is going on. I don't know if I have a caliper being hung up or do I have a master cylinder going bad. Do you anyone else have similar issues? This just started a couple weeks ago and seems to be slowly getting worse
