Official 00-06 Tahoe/Yukon/Escalade drop guide with pics...
23sonthetahoe
Thought this might be a good idea with so many asking about drops...if it doesn't catch on it'll just fade away...if it works maybe sticky it?
This idea is to get a collection of information from everyone on their respective setups with pictures so anyone looking for pics/results/ideas/etc can easily see what has been done & is possible. Edit & update your post as you see fit & as you make changes.
Here's my setup & a possible template to work off of...
Model/Year/2x/4x/AWD:
- 2003 Tahoe LT 4x4
Advertised drop:
- 3"/5.5"
Fender height front/rear:
-31.75/32.25
Front:
- LCA's : DJM 3"
- UCA's : stock
- Spindles : stock
- Sway Bar : BellTech
- Tie Rods : Custom 1" DOM w/ 3/4" chromoly teflon lined heims
- T-bars : stock
- T-bar keys : stock
- Shocks : DJM
- Steering : KYB stabilizer
Rear:
- UTA : C3Fab adjustables
- LTA : C3Fab adjustables w/ DJM relocator kit
- Springs : DJM 4" Trailblazer
- Panhard : Spohn adjustable
- Sway Bar : BellTech w/ DJM end links
- Shocks : BellTech
- Air Assist : None
Wheels & Tires:
- Wheels : 22" Boss 330's
- Tires : Nitto 275/40/22's
Considered upgrades:
- DJM uppers to ease UCA balljoint angles. Noticed occasionaly popping from stock upper joint. Otherwise, nothing.
Brief impressions of setup:
Overall, the ride is firm but not stiff. The suspension has a progressive rate feel to it. Normal driving it's really
tame but it takes corners incredibly with little to no body roll & my confidence is gone long before any talking from
the tires.
Pics:
Good idea? Bad idea?
Cameron
23sonthetahoe
I know this thread is very old but chevys riding real bad and can't find anything on adjusting pinion angle on a lowered suv ? Its an 01 tahoe tire s and rear drop is slightly lore than a 2/3 s because I didn't put spacers back in just the rubber isolators on Eibach drop springs .. beltech drop shocks ... front was only cranked down by the stock torsion bolts and aligned ... any thoughts ?
1992rs
OR
Adjusting pinion angle requires spohn control arms
Bombsquad85
Northern VA
To those of you that got the djm endlinks. I don' 100% understand the directions. I was under the impression that I would just take the old ones off and put these ones on however it looks like that's not the case. Also only 2 bolts were included but I think I may need 4 or 6?
04Huck
"I'd rather be lucky than good"
Buford, Ga
View attachment 198444 View attachment 198445
These are intended to work once you relocate the sway bar. You have to move it over about 3/4-1” to the passenger side, so that the end is between the panhard bar bracket and the shock. If you don’t, when more than 3” lower in the rear, the truck quite literally sits on top of the sway bar. I just got finished installing these about 3 weeks ago. Also, you reuse 2 of the factory bolts and the 2 that are in the kit.
This shows about how far over you need to move it. I bolted the bar up with both endlinks and bolted on the passenger U bracket, then decided where to position the drivers U bracket and marked my holes to drill/tap
memphizhoe
Also don’t tighten the sway bar link bolts over spec. It will make it ride rough in the rear. I’ll look and see if I can find the torque spec.
memphizhoe
It’s 30 on the links and 100 on the panhard bar. daf42162d25a366151f5f358ef239d15.jpg54c19ce32d17aa2f7c381ea6bbd4f13a.jpg
Bombsquad85
Northern VA
What bolts/nuts
did you use for the driver side sway bar bracket? My kit didn'
Come with nuts for its
06Z71TAHOE
