Oil Pressure Sensor gone bad: Remove intake plenum or no?
JT 07LTZ
Western, NC
So after just doing a bunch of work to my Tahoe, now my Oil Pressure Sensor is bad. Check engine light is on and no readout on the oil pressure gauge. After doing some research, I see a lot of conflicting info about if you have to remove the whole intake plenum to replace it or not.
Has anyone dealt with this before?
Da90
Tulsa, OK
I just replaced mine without removing anything but the sensor.
Da90
Tulsa, OK
You are basically doing it blind. Familiarize your self with the area and take your time.
mals
Western Mass
Thanks man. I guess a climb up in the engine bay is in my future
I can't imagine it is much different then my '05 6L that I did a few months ago.
I watched a few youtube videos, and then literally laid a drop cloth over the engine and climbed up and in, chest down and arms between the engine and firewall. I did pop the connection on the solid fuel line to make room for my hand. As said above, you are basically working blind. I used my cellphone to take a few pictures so I could see what orientation the wiring clip was on the sensor which made it easier to feel how to pop it off. Make sure you have a deep 1-1/16 socket on hand with a few universal socket joints and various extension lengths. If I remember correctly, I think I ended up wrapping my universal joints in few wraps of electrical tape, so they were flexible but not floppy.
Other than that, take your time, it will take a few attempts, but it is doable.
JT 07LTZ
JT 07LTZ
Western, NC
I appreciate the advice. I'm not looking forward to this but It beats paying a shop hundreds to do it though. I asked about it and they are convinced that the intake manifold has to come off to get to the sensor.
Parthery
Atlanta, GA
My shop was able to replace the sensor on my 08 5.3 without removing the intake.
One trick is to deflate the front tires...the couple inches that the vehicle is lowered and tilted forward makes it easier to get in there and see what you are doing.
Russ
There is nothing horrible about removing and replacing the plenum to access the oil pressure sensor. I have big hands and would much rather to that than dig blindly at the sensor. It is also a good idea to pull the screen out because it will eventually plug up and you will be doing the job all over again.
Jagsta
I tried to do it blind - after an hour of trying I ended up dropping an extension and socket down to where I couldn't get it. In the end I pulled the plenum, it wasn't that bad. Plus that allowed me to torque the sensor to proper spec. It can be done without removing the intake but I think it's much easier to just pull the intake...
Jcurt
