Ok air conditioner charge lasted 24 hours
Woodblocker55
Woodblocker55
I'm thinking positive maybe it's just clutch issue . [emoji106][emoji15][emoji849][emoji41] I'm going to pickup one of them lights . Yes fuse is good but maybe it not being kicked in and out enough for the last 6 months might have rust and to much clearance. Ok I'm grasping at straws. [emoji37]
Sent from my LGL84VL using Tapatalk
kybob
Just to rule it out, check the relay. Mine was bad and kept dropping out. ( 2004 )
Woodblocker55
Woodblocker55
Update. .. There is a leak in the rear lineset on air conditioner. But if I replace the lines I have to replace the evaporator. Then I may as well put in new coolant lines back there also .. maybe a rear heater core also .. got any tips how to get part cost down .. [emoji15][emoji849] do they make stainless air conditioning line sets ? Or maybe hose the whole way .
rear heater core should be pretty cheap, not sure on the rest but you can check rockauto there is a 5% discount code in the vendor section for them, other places to check are amazon or ebay, it's extremely rare to find any place cheaper than those 3 places
AnonEPTX
