HiHoeSilver
Away!
We have one that you wear yellow glasses to see.
ya uv light is bad for your eyeballsWe have one that you wear yellow glasses to see.
"laser battery" - code word for vape?Said magic light, these are like $8 on eBay, but you have to buy the battery and charger separate, uses the same battery as a handheld laser
View attachment 227609 View attachment 227610
I think most of the vapes use a different style battery or "battery cell", I quite smoking 25 years ago before "vape" was even a thought, when I know my days are numbered I may light up some cherry tobacco in a corncob pipe on my way out."laser battery" - code word for vape?
Mine just takes a single AA battery.Said magic light, these are like $8 on eBay, but you have to buy the battery and charger separate, uses the same battery as a handheld laser
rear heater core should be pretty cheap, not sure on the rest but you can check rockauto there is a 5% discount code in the vendor section for them, other places to check are amazon or ebay, it's extremely rare to find any place cheaper than those 3 placesUpdate. .. There is a leak in the rear lineset on air conditioner. But if I replace the lines I have to replace the evaporator. Then I may as well put in new coolant lines back there also .. maybe a rear heater core also .. got any tips how to get part cost down .. [emoji15][emoji849] do they make stainless air conditioning line sets ? Or maybe hose the whole way .
Sent from my LGL84VL using Tapatalk
