On Start Up Engine Continues To Try To Start-SOLVED
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
Okay def my next step, I may just buy one my wife has an older f150 I'm sure I'll use it again
When you do buy one, get one with an extended hose that allows you to attach and snake thru back of hood and then tape to w/s and can watch the pressure while driving.
wsteele
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
I have heard that you can get the kits at Harbor Freight too. If there is one close to you.
wsteele
My shop manual for the 2007 MY says you have a failing fuel pump. Bummer.
Rockauto.com has the best prices I have seen on GM OE and Delphi units.
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
Definitely the pump for a start but if is bleeding off at the injectors, 10 new pumps will not cure but the way it bleeds back down so quick, to me means the pump. It would have to have a wide open injector to bleed down that quick and if it did it would run like crap.
So, just as quick as "Bob's Your Uncle" here you go: https://www.rockauto.com/en/moreinfo.php?pk=1058530&cc=1433255&pt=10147&jsn=922
BR90
