OR VietVet Is Still Throwing $$$ at 2005 Z71
OR VietVet
OR VietVet
Multnomah Falls
Military
Willamette Valley
Well, maybe he is mad at me or he is out at work for a while. Does anyone know if the part # I supplied from RA is correct for the hydro-boost booster? @915_Tahoe 178-1030? Genuine GM part number? If I recall the one I listed is an AC Delco number
OR VietVet
OR VietVet
Multnomah Falls
Military
Willamette Valley
Can you verify the one currently installed?
I did compare the one on my rig and the pic at RA but mostly it was about an RPO code option and I found the right one, as it turns out, but if I can verify with 915_Tahoe I want to because it is a PITA to order the wrong one and have to go thru the return process.
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
Let's do this cause I'm getting tired of all this ********. Lol
J/k, I'm here to help guys when/what ever you need. Past couple days I've haven't been on here, was looking for a daily car and found one. Been messing with it for a couple days now.
Let me know the callout #'s you are looking for.
OR VietVet
OR VietVet
Multnomah Falls
Military
Willamette Valley
@915_Tahoe, I really appreciate what you do for me and other members.
The 178-1030 number at RA looks like what I have and should be right with the RPO code info. I tried the GM number at RA and came back as Number Not Found.
I then went to GM Parts Warehouse with the 19371355 GM number you gave me and when it does pop up, it is a pic of a vacuum booster.
Went to GM Parts Giant and the same number had a pic of the correct hydro-boost unit.
WEIRD! Thanks again.
BurbyRST
