OR VietVet Is Still Throwing $$$ at 2005 Z71
Weight in the back so you will not nose dive.
Removed the fuel tank that was in front of the axle and on the driver side and installed a Blazer tank that is centered behind the axle. Also relocated the battery to just in front of the axle on the passenger side. Kept a stout nearly-zero-profile fiberglass bed cover on it. A modified Class 3 (or was it 4?) receiver hitch added reinforcement, fuel tank mounts and extra weight at the far rear end of the frame. Oh, and I converted to rear disc brakes and had a proportioning valve adjusted to make it squat really well when standing on the brakes. Stainless steel flex lines. Rotors were cryo-tempered PowerSlots with Hawk HPS pads. I could stand on 'em from triple digits and they never faded or warped in the 10+ years I ran them.
Had 285s in the back with plans and clearance for 315s. It was being built to have a half-decent chance with a high-compression, cammed LQ9 (~450/450 conservatively) and FLT Level 6 moving it.
That would've been a sick S10.
Multnomah Falls
My 20,000th post:
As you can see by the date, it has been a long time since I posted anything here about my Z71. I went thru it and did quite a bit of work and it has never ever let me down and still runs and handles fantastic. I was looking to buy a 2004 K2500HD Silverado but that fell thru and if I bought it, I was likely gonna sell the Tahoe. The road test did not impress and the ride was jarring. Then I remembered that the K2500's ride on the bump stops. It was a crew cab with a short bed and therefore, longer. In my usual traffic, it was gonna take some getting used to with it being longer. I then decided that I did not want it, lots of fluid leaks, and I decided that I cannot replace the Tahoe because I love that truck.
I have "made like new" from the front to back. There are only the a/c system, differentials, engine and transmission, that I have not opened up for work. I have done the maintenance but no repairs. At 165k, it looks and drives better than new with the Black Bear Tune and the Hellwig bars, front and rear. I have decided that if it needs an engine down the road, I will replace it. If it needs a transmission further down the road, I will replace it. If it needs gears, I will replace them and if it needs a/c work, I will gut it and fix it. I love working on that Tahoe. Crawling under it, is a joy. Pulling up in it, reminds me of the work that has been done and that it is beyond reliable.
There is only one thing I do not like about it, The sun/moon roof. I am religious about the seal cleaning and lubing and making sure drain is clear but I feel that one day it will be a PIMA and cause me to make up new curse/swear words. No sweat there, vets know how to pontificate with profanity.
Anyway......at 20,000 posts and hope to be around for 20k more.
My 20,000th post:
You BETTER be around for 20k+ more posts. You presence on this Forum is invaluable to many of us. And, what would we do without your unique sense of humor?
nscherr1
