Ordered my 6.0
BOSS
The People's A D M I N
Dallas
Found a nice big vacuum leak at the egr valve tube going into the s/c. I went ahead and just removed the entire egr crap. I'll just have to deal with the CEL until Justin gets a chance to tune out the egr for me sometime later. Hopefully this will take care of my p0300 misfire code. I still don't think this is what's causing bank two to run lean. I haven't driven it around yet to even see if it took care of my random misfire dtc. I'll find out tomorrow.
Oh yea, btw. I further disassembled the old 5.3 and found 3 melted pistons (pistons 2, 4, and 7), a crack in the number 7 cylinder wall, and a blown head gasket. Found some of the missing pistons melted to the heads. Apparently, my lean issue started with the 5.3 from what it looks like.
Further evidence to run AFR gauge on both sides of the exhaust? ....wow, that's nuts.
Is it 2012 yet?
Austin Texas
Feel your pain brother still working bugs out of mine! I have thought about taking off the egr as well but my question is can it pass the emissions test after Justin reprograms it?
BOSS
Dallas
BUMP for Justin/Jenna
Well if it's like the O2 sensors, when they hook up their computer to the PCM it shows the O2 sensors are still there and functioning. Justin also tuned out my FlexFuel sensor.
Jeff was looking at my truck and I don't have the EGR because mine is the Flex-Fuel type. Here is what I found:
8th digit in VIN:
8 - FlexFuel
T - have EGR
B
JKmotorsports
JKmotorsports
Austin, TX
You might get lucky and pass w/o it. If I'm not mistaken (Justin and Jenna should know), simply removing the egr from the pcm only turns "off" the egr so it doesn't throw codes and illuminate the MIL, so you'll still have slightly higher emissions levels which may cause you to fail the sniffer during inspection. But, it's also going to depend on your current engine combo also. BTW, what else are you still trying to work out on yours? I thought you had it all up and running.
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
:Handshake:
Justin
Quite possible that it went lean and caused that, but excessive time at WOT will also cause heat buildup and could lead to that problem. I do suspect fuel delivery though.
Here is an interesting read on the topic: http://www.kb-silvolite.com/article.php?action=read&A_id=34
961500
Is it 2012 yet?
Austin Texas
ME too I thought most of the issue was the cats needing to be replaced and the plugs being to open. When I went to regap the plugs I noticed cylinder 3 was nice a clean like new the rest had some discoloration. I am not getting fuel into number 3 have spark so I need to pull off the intake and look at the injector. We are having enough isues together we ned to form a self help group AA for the owners of troubled rides!
BOSS
Dallas
Yup, #4 was the plug that was different than the rest on JK's truck. Not sure why as of yet.
B
961500
Is it 2012 yet?
Austin Texas
A lot like JK I think the issue was there before I installed the new motor just didnt know it guess you just get used to it as they age not running the same. Both will be up sooner than later and it will be worth it my ran strong even one cylinder down so I am anxious to say the least.
Hobbitsam
