afpj
- Joined
- Sep 16, 2009
- Posts
- 804
- Reaction score
- 359
Oh, well in that case, ignore my ramblings. Back to our regularly scheduled program....
I would try a old school fix and place some cardboard over 1/2 of the radiator, then go drive it and monitor the temp, if it starts to get too hot instead of normalizing in the center then you can remove some cardboard to get it right. that will also confim if it is "cooling system" related.A good wild a$$ guess, well done.
But the propane system is perfect adjusted to the engine and at least it is technically very simple. The normal PCM is used, no tune at all.
The fuel injectors signal is just routed over the propane controller, and this controller decides, based on if i drive on fuel or propane, if the signal is just passed to the fuel injectors, or converted and send to to the propane nozzles. It must be converted, because the amount of propane is different to fuel, so the opening time for the propane nozzles differ from the calculated fuel injectors time.
The PCM does not know anything of the propane system, so to speak.
The PCM use the O2 Sensors, the mass air flow sensor and all other engine parameters like running on fuel. If i drive on gas, i can switch just with a push on a button to propane and opposite. My car behaves exact the same. You feel no difference.
And also the temperature behave, does not change at all.
should start your own thread, but normal operating temp is around 195-200 roughly it is always flucuating a little bit not enough to see the gauge wiggle but the gauge should normally remain stationary for the most part once it has heated up. different conditions can make the gauge move, elevation, towing, engine load, etc.2004 Escalade with the same issue.
Just changed the thermostat because engine was not heating up. Now the temp does rise, but it takes a while and does not reach 187F (dash gauge remains below the middle mark between 160 and 210 and cabin heat delivery is poor).
Many posts suggest the dash gauge should read 210F but the OEM operating temp is 187F. Would someone be able to clarify?
Why does the cooling system even matter if the engine temp is lower than the thermostat set point? I'm assuming that the thermostat remains fully closed until the temp rises & until then the cooling system is not at play (the thermostat, and only the thermostat, regulates the engine temp). The fans and other parts of the cooling system just ensure cooling capacity, but not access. What am I overlooking here?
Does the thermostat always allow some flow (significant enough to cool)? Is there another pathway to the cooling system?
Thanks to all the helpful advice and suggestions! Forums are awesome & those who share make them awesome!2004 Escalade with the same issue.
I can’t fathom the thermostat sticking “open” causing the engine to never get to temperature. I think it would get there eventually. In my case, the gauge was showing no movement whatsoever, and I drive 75-80 for half an hour each way to work. I also had hot heat in the cab, so I’m confident the engine was actually at its normal temperature range.I have the problem since the beginning and i don't now if the cooler was replaced by the former owner..
Thermostat sticking does just that, overcools the engine and it never gets to its roughly 200deg normal operating temp range. This is the magic number roughly that is required for the engine to warm up too before the PCM will go into closed loop where it actually pays attention to the various engine/exhaust sensors. The engineers figured out after many years that most engines can perform better for emmissions and MPG if they are ran around 200deg. You get more complete combustion because the cylinders are hotter than the OG setups. My old vehicles I had many years ago with Gen 1 sbc would run around 185 or so. If they got to 200deg, there was a problem and better be finding a place to park and figure it out before you cracked a iron head or the block!I can’t fathom the thermostat sticking “open” causing the engine to never get to temperature. I think it would get there eventually. In my case, the gauge was showing no movement whatsoever, and I drive 75-80 for half an hour each way to work. I also had hot heat in the cab, so I’m confident the engine was actually at its normal temperature range.
was the old thermostat actually stuck open? I’m still having a hard time imagining GM designing a cooling so efficient that the engine won’t reach operating temperature if the thermostat is stuck open. GM is famous for underengineering things, and I’ve been wrenching on them for over 40 years, so I’m confident in my skepticism, lol. I’m tempted to take the one I just replaced and gutting it and trying just to satisfy my skepticism.So, I've finally gotten around to taking care of this problem.
Yesterday I built a orifice that I installed in the hose to the cooland reservoir. With the recommended diameter of only 1.5 mm. This made no difference at all on two longer trips. Which means, I assume this isn't my problem.
Of course, I don't mean to say that this isn't the problem in other cases, but I looked at the exit of my cooler and there is a narrow orifice in there, that has a maximum diameter of 4 mm. I couldn't measure it that precisely. But with a really small passby it makes absolutely no difference.
Based on human judgment and the way the cooling system is designed, this can actually only be the thermostat.
I'm surprised that I had this problem with the old thermostat. Then I installed a new one and the problem hardly changed. Of course it could be a coincidence that the other, new thermostat is stuck in the same way as the old one.
I have now simply ordered a new thermostat and will replace it again.
I will report...
