**PICS** My CUSTOM Intake
BlizzardX23
BlizzardX23
Sacramento, California
LOL...I dont plan on doing any mud bogging...haha but thanks for the heads up...
*HOWEVER* If I do decide to go deep water forging, or mud bogging, its a simple fix...pull the 90 degree elbow along with the long tube, disconnect the bottom section and leave it mounted...and rotate it back to the stock position with a filter on it :)
Did you have a CAI kit before you made your own? and how much of a difference did it make once you started pulling true cold air from the front of your bumper?
Nickleahy23
Portage/Menomonie, WI
haha just be careful..im sure mine acted like a scoop to pick up as much water as possible..
i honestly gained 2 mpg on the interstate, maybe 1 in town..it has more power at higher speed since some air is actually getting forced in..i also took my stock intake tube and cut off the silencer box and patched it up so now its just straight through..
Max
Mile High
Denver
The bottom of my aem gets damp when it rains, just gotta be careful.
Oklahoma
I know this is a bit LONGER then my K&N tube, but I believe the true COLD air will outweigh the length issue
Home Depot Project Supplies
Throttle Body --> Coupling --> MAF --> Coupling
Throttle Body --> Coupling --> MAF --> Coupling --> 90 Degree Elbow
Insulating the elbow then wrapping in reflective tape
Both insulated parts put together
Im just going to find a "Y" piece similar to that and run it through my skid plate and into the pipe
I like really that huh?? one of a kind post up how that work's might try that
MOBmentality
Has a $25,000 Punch
i just beat off to the spectre dualy FTW that thing is nice
Edog911
