Popping/Clunking Sounds during Right Turns?
Black Market
So my 2007 SSV has developed a popping/clunking sound when making right turns...it is somewhat intermittent but is more pronounced on harder turns.
Any ideas on what I am up against here?
---------- Post added at 10:28 AM ---------- Previous post was at 09:17 AM ----------
So reviewing previous posts it looks like there are a number of potential culprits:
- Slip yoke may need greasing
- Alignment cam bolts may need to be tightened
- Wheel bearing may be shot
- Bad tie rod/ball joint
- Busted motor mount
- Busted sway bar link bracket
These seem to be common issues with the NBS...
Black Market
Black Market
Well the mystery has been solved...Two busted sway bar links. Glad it wasn't a wheel bearing!
Damien1990
Just had to replace mine over the weekend. It rattled on every bump, had a look at them and all their bushing were blown out. Went with the Moog kit.
Black Market
Black Market
Yep...Went with the Moog kit as well. Had to borrow a buddies sawzall to get the old ones out. Once the old ones were out it was a quick job!
darkmarius
