Post your 2wd lifted with spindles
Wicked Mayhem
Who all is running lift spindles? Wife has a 2016 2wd and wants it lifted 4+ inches. Wanted to see some pics of some 2wd’s and how much front and rear lift and tire sizes and what brand spindles you used.
Thanks
W
Wicked Mayhem
Who makes lift spindles for a 2wd Denali?
Sent from my Pixel 2 XL using Tapatalk
Assuming it’s the same spindle as a Tahoe, they sell a 5” lift spindle for them. You’ll have to look at your control arms to see which spindles you’ll need. If you have aluminum or stamped steel arms you’ll need x spindle. But if you have cast steel arms you’ll need a different part number. Problem is they’re 5” lift, not sure how much you can lift the rear with taller springs or a coil spacers and shock extenders etc before you’ll need drop brackets for the front of the 4 link, or adjustable arms to get the axle back in the center of the wheel well. And obviously an adjustable pan hard.
OklahomaSideShow
