Post your lifts.
liftedtahoe
arkansas
Need to get new pics but here is the gist
Here is the rear
That's clearance you want to fit 35s!
These are all old pics. Will get some new pics tmrw as the stance was adjusted and changed as well as track width in front.
What size lift you got?
Sent from my SAMSUNG-SM-N910A using Tapatalk
hoe
6" super lift up front with 3" lift spindles. Pretty much decrunk stock keys all the way out till I lift the rear. Pro comp 4" kit with 1.5" rear spacer. Going to go with a 3" Spacer and level the front to match. So overall it should be set at 7-8" lift when done!
liftedtahoe
arkansas
You can fit bigger than 35s under there! Right?
liftedtahoe
arkansas
Cuz I have 35s on mine and not near that much lift
hoe
Yes you can! I just hate the stuffed look. But I'm pretty sure I can fit 37s. I'm sticking with my 35s though for full articulation. I also don't have any body lift so tires can get close to the body with extreme off roading. I have 0 rubbing and have done major triming as well.
liftedtahoe
arkansas
Yes you can! I just hate the stuffed look. But I'm pretty sure I can fit 37s. I'm sticking with my 35s though for full articulation. I also don't have any body lift so tires can get close to the body with extreme off roading. I have 0 rubbing and have done major trimingb as well.
Tuechè [emoji106]
Antonio Estrada
Fort Worth Tx
Hey im looking to lift my denali in the front more i have ready lift 3in torsion keys cranked all the way my front shocks are worn out and since they are finally out i wanna go to 6in lift just up front an thoughts on what i can do or buy to get those 6inches up front ? Id appreciate the response thanks in advance. download_20160221_230354.jpegdownload_20160221_230354.jpeg
Antonio Estrada
Fort Worth Tx
liftedtahoe
arkansas
Hey im looking to lift my denali in the front more i have ready lift 3in torsion keys cranked all the way my front shocks are worn out and since they are finally out i wanna go to 6in lift just up front an thoughts on what i can do or buy to get those 6inches up front ? Id appreciate the response thanks in advance. View attachment 59735
Awd?
JPS04Baby
