Purchased a 2007 Yukon XL, now to make it reliable!
GMT800 SUV/Trucks
You are correct! It looks like it’s coming from the oil cooler block off. I’m going to replace the gasket and go from there.
IMO, I would not reuse the plate because it is likely warped and will leak again. Buy a Billet plate and a new o-ring seal and call it good. Clean the old oil off the whole area and then keep an eye on it for future leaks.
Y
YukonGold12
Changed the block off gasket. Drove 180 miles. No more leaks from that section anymore. Now some oil accumulating at the base of the pan and at the top around those bolts. Going to need to track those down, there isn’t oil under the car anymore after it sits for some time. Which seems to be resolved from that gasket replacement.
It looks like there is something accumulating around the diff. I had cleaned that area last night when I changed the oil.
Y
YukonGold12
Worked on the truck again today.
- Changed spark plugs and spark plug wires
- MAF sensor cleaned
- Air filter replaced
That #8 plug was kind of a pain, but I decided early on I was going to attack it from the wheel well, removing the liner and everything made that easy.
Old plugs were toast. I've attached some pictures of the plugs and I scoped the cylinders for y'alls enjoyment.
The engine seems to be idling much better, although still some work to be done.
Y
YukonGold12
The rest of the cylinders.
Y
YukonGold12
Spark plugs 1,3,5,7
Y
YukonGold12
Spark plugs 2,4,6,8
Gil Carreau
