question on ordering front wheel bearing
2006Tahoe2WD
Silicon Valley
okay, I got the Delco Gold front bearing assemblies. I have one installed and ran out of time. Those T50? socket pins that hold the caliper to the frame were tight. I read those were T50 but a T50 isn't very tight. Is it a T55? or ? Had to use vice grips and a hammer to get them started and then inserted a 7?mm hex - it fit tightish. The bearing came out easy after the 3 15mm bolts are out - those were tight also and had some sort of lock-tite applied. After a test drive I still hear a bit of what I was hearing. I think my back axle(s) are bad (inner bearing races). The noise will likely come back to the same level when the rear end fluid gets hotter than my test drive. I know one was wearing badly about 40k miles ago or so. I'll install the other bearing tomorrow. I didn't have any ABS codes or issues so far. I guess I'll save the "old" bearings for awhile in case the new Delcos go bad. Nice project - at least I'll have new bearings and can cross that off the list.
2006Tahoe2WD
Silicon Valley
I ordered new bolts (hub to knuckle 15mm hex) and slide bolts (T55 changed to 18mm hex). Here are the torque specs. I found.
Hub to knuckle (3 bolts) 133 ft-lbs - this feels like pushing it for a 3/8" adapter
Caliper slide bolt (2 per side) 80 ft-lbs
Caliper frame to knuckle (2 per side) 139 ft-lbs
Wheel nut (6 per wheel) 140 ft-lbs
Does this agree with what others have found?
Thanks.
2006Tahoe2WD
Silicon Valley
Another question. Rubber/plastic bushings about 1" long came with the new guide pins. I assume I should take the old ones out and put these in. Can someone explain a bit about this? E.g. how to get the old ones out. I forgot to look it there is a way to punch them out. Thanks.
See picture.
MassHoe04
Western MA
I have never replaced any like that, but they would go into the outer side of the caliper bracket, where the narrowest end of the guide pins sit.
Did you get new rubber boots for the caliper pins too?
Were the originals worn out or really rusted, preventing the calipers from working properly or were you just looking to make it look pretty when the new hubs go in?
If the caliper, pins & boots were all in good working condition, I probably wouldn't have bothered just putting in new guide pins for the sake of doing only that.
Those accordian-looking boots are important parts needed to keep water out of the guide pin. They should be flexible to move with the caliper and not cracked or split.
2006Tahoe2WD
Silicon Valley
I did not get new boots. I'm changing the pins because I don't like the T55 head. The T55 heads got messed up a bit during extraction and I'm replacing with new pins that have the M18 hex head.
MassHoe04
Western MA
Yeah... That makes sense.
Maybe not something intended for you, but a side note for other members who might be new to caliper removal/replacements:
Breaker bar is best bet for caliper guide pin removals. Avoid the temptation to use impact wrench if you are not certain the pins will come out easily.
Impact wrench can strip out the T55 head or snap the guide pin with the hex heads, if water gets into the boot and rusts the pin into threads of the caliper bracket.
Heating the heads of the guide pins and soaking with good penetrating oil may be required to get stubborn pins out.
Proper sizing on the star bit or socket is also important to prevent stripping or rounding over of the heads during removal/installation.
2006Tahoe2WD
Silicon Valley
There are a few videos out there showing how to clamp the breaker bar against the caliper to reduce chances of stripping the T55. I'm going to try this in about 1 hour. I'll see how it feels and then resort to impact clamped against the caliper with low air pressure.
as already mentioned I would avoid a impact period some of those bolts are aluminum (on my 2012 they are) and a impact will round it out before you can even blink an eye, use a BIG breaker bar and turn the wheel/hub out so you can get in there
2006Tahoe2WD
Silicon Valley
I finished installing the other bearing along with new guide pins/bushings and the 3 bolts that hold the bearing in. Here is my setup for getting the T55 to move and not stripping it. Note socket to stop the caliper from sliding when under pressure from the clamp.
Here is the situation after taking the bearing out. No rust in the bore and it came right out without doing anything.
Here is my remaining pad material - maybe go another year on these.
I did buff the stainless clips after this picture.
nuggettss1
