2006 Chevy Tahoe LS 5.3 engine
Sooo.... been dealing with multiple transmission rebuilds since last June. Truck has 242,109 on it right now. Tranny last year started to go bad so I had a reputable local shop rebuild it. Couple months later the torque convertor went bad again. They replaced it. Couple months later, same thing happened along with another gear busting going up a mountain. Had to tow 100 miles back home. They rebuilt again and the same results. However..... this time when they opened it up the tranny fluid looked like stawberry mix fluid. They said the radiator tranny cooler had failed and dumped coolant into my tranny cooler lines. They would not cover it under warranty. I get it.... pissed, but I get it.
Took the tuck to AAMCO and had them rebuild it. No offense to the other company, but I wanted someone else to rebuilt.. just in case. Not gonna keep up with the same story, but the same scenario above has just happened again. This time though, AAMCO installed a new radiator and cooler lines so it is under warranty.
It is currently being rebuilt again. This will be the 2nd radiator AAMCO will install. We decided to bypass the radiator this time, as I don't tow a lot of stuff and quite frankly I am not gonna have the tranny die from coolant again.
My question is this.... is there something lurking and hiding in the coolant system that is causing the radiator cooler to fail and take the tranny out? Water temp has been spot-on and never any issues.
The radiator is the most replaced item on this truck with a grand total of 5 since I have owned it. Bought it with 125,000 on it. The other radiators just busted around the drivers side and leaked radiator fluid.
Any help with this would be great.
