its been 3 days, still no chiller
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
edit*** but i did get shipping info!
ordered some more junk. the morimoto led fogs, some projector retrofits, and a new painted front bumper.
somewhere along the way i did order the hella time delay off relay, it showed up yesterday. info a little scattered on these relays. they clearly say 10a on them, but they seem a lot better built than the chinese "80amp" relays ive used some of. but if you look at hella catelog it says theyre good for 20amp switching load for up to 30mins, so in my case i may exceed that slightly if this pump is full bore but only for a few seconds at the most. so i hooked it up, wrong at first of course. didnt do any time delaying, dug back thru hella info and found wiring schematic. i was switching the ground, but the ground completes the time delay circuit and needs to be connected at all times to function. so after i got that fixed it all seems well, set the dip switches and set it for about a 15 second delay.
its been a little cool so i drove it around for a while last night, it gets the turbo spoolin mighty well with such a short charge pipe, used to be somewhat managable in first but it seems to spin a lot easier and max out the gm map sensor @255hkpa
![996152131_02.png 996152131_02.png](https://www.tahoeyukonforum.com/data/attachments/261/261839-07c91743c9955ef45f5b0c12343a656f.jpg)
