randeez
That does suck but it's not the worst thing ever. i guess the Leak down will tell you more.
yep, unless something else magically appears as to why else its blowing out coolant in the meantime i just want to get HGs here if i dont use em now im sure at some point ill need them.
when i did the compression test i also pressurized the coolant system up to just below the cap rating and it held fine for 10+ mins, was waiting for the leak down tester to show up but i was pretty confident it wasnt an issue at that time. no where near what the cylinder pressure puts on the head gasket tho
