Insane!now you need to find this guy to race
I like chrome. I approveChrome 22" 7 spoke
So, while we’re waiting to see what GME (yolo) is gonna do, what wheels dija get![]()
Ok, I've got to ask.
The chiller is essentially an A/C evaporator built into the intake manifold, used to drop IAT, correct?
If this is the case, then doesn't the condensation from the evaporator drip inside the intake manifold and into the engine?
I realize it is probably not enough to cause any harm. As a matter of fact I am a big proponent of dripping water into the intake once in a while to help clean the combustion chamber and get rid of carbon build up.
Anyway, I was just curious as I'm not terribly familiar with the chiller systems.
close kb, and im glad you asked
this is a few things going on. the a2w intercooler/intake, tank, pump, and the chiller. liquid (antifreeze in this case cause it gets down close/below the freezing point of water) circulates thru the entire thing, starting at the tank>pump> IC>chiller> back to tank.
the chiller simply cools the antifreeze similar to how a water cooler works, liquid (antifreeze) to liquid (refrigerant/freon) "brick", tied into the ac system
you would be correct that the temp difference between the air hitting the cooled intake would form some condensation inside, i am however sucking in 100+ degree air and compressing it causing the temp to rise even more, so the humidity in it is probably a lot lower than the ambient air. and whatever does form further cools the intake charge as it gets sucked in
