Randeez 2012 Budget Yukon Denali Build (stick on hood scoops galore)
Dantheman1540
Sugar Loaf Mountain
i think i have a carquest lifetime warranty one sitting here not installed i can go swap for free and see if its better
and i got caught at the slowest and longest train, i forced the ac compressor on thru hptuners and idle was good for like 10+minutes waiting for it to pass. so i need to figure out how to just force the thing on but i think its controlled thru the bcm
When I command the compressor on the AC is awesome but the idle gets even worse as if all adaptives for having the AC on arent active and it will easily stall. It also seems to throw the fueling way off.
Idk if you’ve logged AC high pressure shutoff but when mines cycling randomly it always says the high pressure switch is tripping the shutoff. Even tho I’m 99% sure it’s not having pressure spikes.
randeez
randeez
south florida
i had not been logging ac high pressure, i added the channel and did a quick log - mine just cycles apparently no high pressure :(
also, i bought a new car
Administrator
Also finally got tracking number for yukon coilovers @07Burb
any tips for installation? :oops:
I know you're being silly but should be very straight forward. They are good quality. You'll have to ask feller who's picking up Suburban how install actually goes. He should be on TYF with the Burb. :)
I've tossed around getting them for my Denali but haven't gotten to it yet.
CaptPat
