Randeez 2012 Budget Yukon Denali Build (stick on hood scoops galore)
kbuskill
NE. FL.
ordered new turbo blanket, and also ordered an "exhaust sleeve" to try and put over the downpipe atleast in the engine bay. going to be a little tricky since the wastegate dumps into it - but hoping i can cut the sleeve and install from one side with enough overlap to install it from the other end for pretty much full coverage of it.
another thing i noticed is i havent had any throttle body issues for a while (knock on wood), only real change was cutting the bov spring down some to let it blow off a little sooner. havent had problems for a while even before the much smaller charge pipe so pretty happy with that
Cooked relay, was nice having it delayed off, but relay wasn't up to the task
Maybe get the same time delay relay and use it to trigger a (bigger/heavy duty) higher amperage standard relay???
randeez
randeez
south florida
i need to clean it all up .... im looking at installing something like this, putting the main feed on a large 100amp+ solid state relay. i've got so much wiring going all over the place would be nice to consolidate it all
randeez
randeez
south florida
Well it's faster than anything I own, I'd blame covid for the slower times.
<3
this was also with intake temps pretty much equal too what they were before since i didnt cool it down enough (10.4 run, best was a 10.3 last time i ran the a2a) the 10.3 run went faster to the 1/8th i think.
these runs the tune still needed a bit of work the race against the mustang was the actual first race where i didnt cool enough 10.4
2nd was against the camaro that i cooled like hell but boost went to the moon and cut out a few times before i let out.
3rd i turned it way down and i think only made like 18psi peak thru the run to a 10.7
GetGood
