Random 4x4 switch
_Spanish_
So i recently upgraded to a 04 gmc yukon slt in perfect condition however every time i start it seems to randomly start in a different 4x4 setting. It only changes from 2WD to 4WD to just nutural... Meaning sometimes i am driving and notice that the truck started in nutural but its working properly... When it starts in 2wd it works perfectly.
It never really goes into automatic 4wd.
Now when it starts in 4x4 i notice while im driving because when i get on the gas the transmission wont downshift.
My question is weather anyone has had/heard this issue before so i know if it's the switch or a new 4x4 actuator or i guess something else.
Thank you!
osiris94ej
Casper Wyoming
There will be a code stored in the transfer case segment. More than likely it is encoder circuit code. You either replace the whole shift motor, expensive option. Or you can take the it out, take it apart and swap the encoder ring. $100 part, Dorman makes one. Dealer didn't list it separately.
Sent from my SM-N920V using Tapatalk
_Spanish_
_Spanish_
Oh ic, thank you for your help!
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
This is what I was going to say to a "T".
Part:
http://www.amazon.com/Dorman-600-12...automotive&vehicleId=3&vehicleType=automotive
How to:
http://www.fullsizechevy.com/forum/...-encoder-motor-sensor-replacement-w-pics.html
It's pretty easy to do if you can use a wrench and have a basic set of tools.
_Spanish_
_Spanish_
cjprod0684
