rear is rubbing.
Richi5280
oklahoma
Have a 4wd yukon lowered it 2-3 ended up getting the wrong one so the coils for the back didn't work. Got the belltech 3-4in drop in the rear but it rubs against the metal. I have 26" rims wheels are 305/30/26". What do you guys recommend wheel spacers?? Any one else have a 4wd lowered or just any feed back would help
yates ™
Resident Apple hater
Iowa
Rubbing inside or outside of tire? You well rub a little in the inner fender.
Richi5280
Richi5280
oklahoma
It's rubbing inside. right on the edge of the tires I took a look yesterday and you can see rubber has been coming off
yates ™
Iowa
What is the tire rubbing on? I would assume if it was inner it would run on the plastic inner fender which should not tear up your tire. I think if you ran a spacer you would rub on the fender.
Richi5280
Richi5280
oklahoma
I will try and jack it up this weekend to take a good look. But it's rubbing against some metal bc the plastic is pretty ate up I will try and post pics once I check it out
Richi5280
Richi5280
oklahoma
Took a picture of what is rubbing. What do you guys think? Anyone else had this problem?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Is it only the rubber liner?? If not you can throw a spacer on in the rear to push it out or get the djm hardware kit this will push it back and also fix the swaybar angle. If you look at the swaybar you can see its like this \ it should be like this ---
Richi5280
Richi5280
oklahoma
Would you happen to know what kind of spacers I would need? Or any good ones out there
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Is it rubbing on plastic or is it rubbing on the bolt?
Richi5280
Richi5280
oklahoma
At first I thought it was only the plastic but when we took a look it's the bolt and whatever that bolt is bolted on to.
Enrique01
