Rear lift springs???
GroceryRunnr
I'm just getting started looking into lift ideas for my 2016 Tahoe but it seems there are only spacers available to lift the rear of the tahoe in the 2-3" range? Does no one make aftermarket springs that lift the rear 2-3"? I plan to 4-wheel my Tahoe a little bit getting to some dispersed camping areas and I like the idea of having better articulation/wheel travel in the rear suspension but if spacers are the only choice then I guess that's what I will use
I had a tacoma before my tahoe and jeeps before that, so the lack of aftermarket is definitely frustrating. Thank god for this forum though... tons of good info
Just wondering which route you ended up going?
I am currently in the process of getting a Cognito kit with Fox shocks installed, which raises the front 3”.
I’d prefer a replacement coil for the rear, opposed to a spacer, considering some of the off roading I do.
Can anyone confirm if OEM z71 rear springs will provide a lift over the non z71 Tahoe.
Or if there are any good alternatives…
Fifty
Yes.
I have the z71 suburban border patrol springs.
I’m trying to remember how much lift over a Denali xl spring. Iwant to say it’s in a post
Running 10” shocks, started with multimatics and now running ADS Racing.
GroceryRunnr
Yes.
Awesome!
I appreciate the info and that vid!
GroceryRunnr
Part numbers and specs on the springs in the video. Including the spring rates of them, measurements etc etc
Not sure if I missed it… But is the part number in the video?
Here’s the info you provided for the Tahoe
Which I don’t see any part #
Fifty
I think I listed 2 springs. One is for the Tahoe/Yukon and one is for the suburban/XL.
The difference is the spring rate. All external lengths are identical. But the stiffer spring rate (suburban/XL) will give the taller stance and more load capacity.
Not a lot, just a bit, because it’s simply to make up for the weight increase of the longer vehicle.
Again, I’m running the suburban springs on my XL.
Kerronic
I’ve been looking into getting these haven’t seen a 2015+ with them yet tho
Kerronic
Currently running 2.5” front spacer with 1” rear spacer on 275/70/17 but wanted to get the 2in rear lift dobinsons springs with some new coilovers up front
Jisnis
Me too. Been searching for someone with these on but can't find anything.
bobwass
