donjetman
- Joined
- Oct 22, 2018
- Posts
- 1,664
- Reaction score
- 2,948
I think so, its all in the link I posted.Isn’t it the torque converter on these trannys that should be replaced also?
The rear cover has a gasket that can leak for sure. I replace the rear cover and rear main seal as one unit when I have done this. Never heard of the bolts coming loose but I’m sure it’s possible if the proper torque and application of locktite isn’t followed.Now I am curious. Has anybody checked if those rear main seal cover bolts came loose like the VLOM bolts? Or perimeter gasket failure compared to the actual rear main seal failure?
No tool needed for the rear cover with the seal already installed in it afaik but there is a specific install procedure for the rear cover that needs to be followed. I suggest paying for a subscription to alldatadiy so you have access to the service manual. You want to make sure you do this right considering you have to pull the trans to get to it. This isn’t something I would be winging it on.Well my leak seems to be coming from the bottom of the seal. More than likely it was leaking enough and the flexplate/crank was slinging it around in the bellhousing.
Is it necessary to use the rear cover alignment tool. The kit I have came with a new cover and the seal already installed in it. Most of the videos I have seen the seal is removed to use the alignment tool.
