The ideal compression is gunna vary for what you want out of it.Very true. I'm contemplating on building this myself or having the machine shop assemble it. This would be my first, that is why I'm not quite sure. I have a good friend to rely on if I do go that route.
What cr would be ideal?
Also, would you get a complete rotating assembly or piece together a set?
Sounds like you have a plan already in the making, haha. What gen Camaro do you have?
Pure na and never look back: low to mid 11:1 (or push it close to 12:1 if you have a good tuner, fuel, and like to live dangerously lol)
Decent Na with boost for the future: 10-ish:1 (would make a nice reactive low boost engine or has wiggle room to lower cr)
High boost sob: low-mid 9:1
Anemic engine with biblical levels of boost: anything below 8:1
All those numbers are open to interpretation as static compression ratio doesn't tell the whole picture. Your cam profile can severely impact your dynamic compression ratio (all the figures above are static compression ratio) which is the more important cr to look at. Also, alternative fuels like ethanol, methanol will allow you to run higher compression ratios
Buying a rotating assemblies nice because it can come already balanced, however some builds that are unique will require a piston that's not available in a kit. Texas speeds a good site to look at your options.
There's a popular book called "how to build high performance Chevy ls1/6 v8's" it's a little outdated but it's like the bible of building ls engines.
Mines a third gen Camaro. I've had it since I was 16 so it's part restoration, part moding. It's a project to say the least lol
Sorry to derail op but hopefully you will find this informative towards your choice
