Rocket Man's 2008 Bagged CC Silverado Build AKA "THE MACHINE"
So I watched a couple other videos and saw a method of putting the suction to one leg, so it sucks through the foam and then wrapping the ends of the bag together as best as possible. And I also noticed my vacuum nozzle had vents in it so you couldn’t suck too hard I guess. I taped up the holes, tried that method and it worked great. Also, after pulling the original plastic bag off I saw the old cloth cover was still on so I cut it off. Then I added foam to the front and back and used the method. Still not tight enough so I added foam to the sides too. I used a bench vise to hold the headrest and quick grip to hold the vacuum nozzle. After it suctioned down I could let loose and use both hands to work the cover over. It was easy.
D651F076-AB0C-4F8C-B17E-BE6A0ADB3E34.jpeg 47518146-A0EE-4B6E-BCD4-0F3A47D574DF.jpeg 3A53782C-6A0D-4A74-8840-1ACDD6A012A3.jpeg 5566A92E-CC0A-4F7F-950C-50043DF7C0F9.jpeg
yates ™
Resident Apple hater
Iowa
Got one of the headrest covers on and was hoping I wouldn’t have to add the foam they included for the 08’s. They said the cover probably wouldn’t be tight enough and they’re right. It’s gonna be a ***** to fit these things over something even bigger than what I just did. They show use of a shop vac and plastic bag in the video in order to make the foam smaller. I tried it but my vacuum didn’t do much it seemed like.
View attachment 238737 View attachment 238738
I remember the headrests being one of the hardest parts.
The rears from start to finish. First I removed the OEM leather, then the OEM fabric. Then set it up on the vise, bagged it, suctioned it, pulled the cover over it. Turned the vacuum off and it reformed but was a tad wrinkled.
405355D9-A791-436A-9C00-ABCB877E3C9C.jpeg 76962FF7-FDA0-44D9-A430-16281B7D68B3.jpeg 61E7EE24-23DC-4A56-8B24-502567E5F4DD.jpeg 83B8D3E3-8B20-4DE1-836A-6D3679370648.jpeg AFE41DB7-CFB0-493F-923A-6F12947FE70A.jpeg
I pulled the bottom off the DS front seat, attached wires instead of zip ties, and reinstalled it. This time all the points where there were broken clips had something holding it. I steamed the hell out of the bottom and back and reattached the hooks. It’s as good as it’s gonna get. I used my new stapler and attached the back fabric to the seat back. Just need to put the plastic trim on the base.
5672864A-7419-4FD6-A1CB-2E2EBD0303F2.jpeg 77A188A4-8BE9-468E-8AE2-BF79E2457867.jpeg AD053BA3-6423-428D-9567-EA07F2FC9B72.jpeg 2C1D60F8-3C55-413E-AA31-F6F2BFBECBC2.jpeg
Sam Harris
Texas
View attachment 238801 View attachment 238802 View attachment 238803 View attachment 238804
Puppers supervising. Good dog!
hawk Eric
