I was going to install both rear door panels today but ran into a couple snags. First was the latch cable. The one from the wrecking yard labeled left rear was too short so I used the one from the right rear which was a few inches longer for some reason, so I need another for the right rear. The one on the right in the pic is the one for the LT panel, the one next to it is the one they pulled from the left rear and is too short, the others are fronts. The other snag is the bolt that’s by the new latch handle- there’s nothing on my door for it to screw into. There’s just a rectangular hole which I thought was for a nut clip but I found one and it doesn’t work. I will research, because this bolt is needed so when you pull that handle you don’t pull it off the panel.
![068DF930-10C2-4A75-9BCE-A6CEDBD8E138.jpeg 068DF930-10C2-4A75-9BCE-A6CEDBD8E138.jpeg](https://www.tahoeyukonforum.com/data/attachments/235/235781-013464b0905e90ee03bb843effe339f0.jpg)
![67A28624-1932-41BE-9851-42A0B2F12D1F.jpeg 67A28624-1932-41BE-9851-42A0B2F12D1F.jpeg](https://www.tahoeyukonforum.com/data/attachments/235/235778-4521b0328494d05fe212c281554f53d2.jpg)
![2C4617A8-DA06-4AEF-BA36-DE33B503859A.jpeg 2C4617A8-DA06-4AEF-BA36-DE33B503859A.jpeg](https://www.tahoeyukonforum.com/data/attachments/235/235779-e7ac85686db1ee6c9fec31af48e96355.jpg)
![133EF220-E95A-4690-8F3C-AD4DAE427753.jpeg 133EF220-E95A-4690-8F3C-AD4DAE427753.jpeg](https://www.tahoeyukonforum.com/data/attachments/235/235780-24dacf05c078415858b091cf25571113.jpg)
