Safely long-haul towing with a 2006 Z71 Tahoe
Mudsport96
40.923,-89.488. Illinois
I laughed a lot at #4. (Oakfield, which is 20 miles shy of Houlton. Basically I-95 from Portland to Canada lol)
So a good bit further north. That's cool. Ive haven't been out there in a very long time. Got family in Biddeford so that's how I have an idea of where you are traveling. Long drive and massive weather change, going to the ice box zone, or you going back to Florida for the winter?
JCODOHERTY
SE Connecticut
Keep her in 3rd gear and don't be overly aggressive with the throttle. LS motors are rpm Champs and don't care running for extended hours like that. Fresh oil change and Trans service beforehand. Maybe even a diff service too if it's been awhile.
You'll have good airflow at 55-60 so temps won't be a problem. If you start creeping towards the 230 mark, you might want to slow down or give it a rest stop. Leave the truck running all the time for quick rest stops or fuel upside. Shutting off just heat soaks and cooks stuff.
Excellent answer
SnowDrifter
Washington. The starbucks side not the desert side
Excellent answer
If you need to park it for cooling, flip the a/c on
That will kick your efans on and pull air through the radiator. Else they will only activate based on coolant temp. Which flows through the radiator, and across the transmission's radiator-located heat-exchanger.
Hot coolant through rad (tstat open, cooling fan off) does a better job of warming transmission fluid than cooling it. Pull some cool air across both the external cooler, and the radiator (and in turn, cool fluid across the heat exchanger)
nonickatall
Germany
The distinction is crucial. SnowDrifter is absolutely right. Radiator sidetanks are NOT coolers.
Radiator sidetanks are Heat Exchangers.
That is correct, in case of the automatic transmission, it should help to get the transmission fast on operating temperature, by exchange Temperatur with the engine coolant. There is not much cooling, except the temperature ist above water temperature. But the cooling surface is far too small to cool efficiently.
03yukXL
if you don’t have a trans cooler install one as others have suggested.
Obd2 scanner can read your trans temp from the internal sensor. May be worth the 15-20 bucks to get one. Mind works great!
Brakes. I would give them a once over.
RobH
San Antonio
My transmission went south on me during a trip from Texas to Florida to Pennsylvania and back to Texas in April. It became very apparent in South Carolina. I got a fluid flush which helped for a little while. I changed to driving at 2000 RPM at about 60 MPH on the interstates and nursed it home. I would have skipped Pennsylvania and come straight home except that my brother-in-law was going in for surgery and I wanted to see him.
Heat probably killed my stock 6L80E tranny's torque converter lockup clutch, known 6L80E failure mode. It began slipping, with engine RPM rising and falling as I went up and down hills on I-95. It probably sloughed off material which contaminated the rest of the tranny. Shifts became delayed and very abrupt. I would back off on the gas pedal going up hills to try to minimize slipping. This was with just me in the Tahoe and no trailer.
I'd try to keep the transmission temp below 200°. Pulling into a rest area and shutting down the engine and raising the hood allowed me to get the trans temp down from 195° to 155° in about thirty minutes while I ate lunch or walked around. When I got gas, I did the same thing. Raising the hood assisted convection cooling of the radiator, transmission oil cooler, engine, and tranny.
Your fans probably don't come on until 200°F or more engine temp. If you can get a tune to keep the fans running when engine coolant temps go above 180-190° that will help your engine and tranny survive. Their thermostats will use as much of the cooler coolant as needed to keep temps reasonable. Personally, I don't like to see engine temps higher than 200-210 and transmission temps higher than 180-190.
My replacement 6L80 has the factory service bulletin 158°F (70°C) thermal bypass valve. I don't know if your 4L60 has a thermal bypass valve/thermostat or not. An additional, bigger, inline transmission fluid cooler may help avoid a trip interruption, especially in August or May.
You might consider getting a Scan Gauge II. I've used the same one on three different vehicles. I always keep one of the four gauges on engine temp. One of the "XGauges" will display your transmission temp. It plugs into the OBDII diagnostic connecter under the dash.
www.scangauge.com Manual attached.
Good luck with your move. :)
  • Scan_Gauge_II_Manual_51.pdf
Marky Dissod
MOST people think of some variant of 'more power' when they think of pcm / ecm & tcm tuning.
Power is NOT the most important thing addressed by a proper tune.
The most important things addressed by a tune improve the powertrain's longevity and durability.
1. Most obvious would be colder fan-on thresholds to lower the powertrain's operating temps.
GM prefers the motor oil and ATF hotter, for minimal friction possible, so you get 1 or 2MpG more.
If any underhood stuff needs servicing / replacing sooner / more often from the extra heat, oh well.
If you prefer it a bit cooler underhood, so you don't have to replace those coolant connections quite as often,
get tuned.
2. ...
Marky Dissod
2. Another thing more important than 'powah' is transmission tuning.
GM's OE 'Normal' shift table is written expressly to maximize a given vehicle's CAFE MpG score on a test that seldom resembles how even conservatively normal drivers drive in the real world.
Transmissions are commanded to upshift to top gear as soon as possible, and avoid downshifts unless the driver applies a whole lotta throttle, discouraging enthusiastic driving.
Since 1995, GM programs the torque converter clutch (TCC) to engage and disengage progressively, so that the driver and riders barely notice. The price is more TCC wear.
Proper transmission shift tuning reduces unnecessary upshifts and downshifts, which directly impacts transmission longevity and durability.
Locking and unlocking the TCC positively, extends the TCC's lifespan considerably, which ultimately delays rebuilds.
There's FAR much more to pcm / ecm & tcm tuning than the above.
Without going into more detail, hopefully the above will help the hesitant understand why a proper aftermarket tune will help a vehicle powertrain last longer and perform better than GM's OE calibration.
Alex_M
I've towed a lot with my high mileage Tahoe at and we'll above the rated tow capacity, albeit with a rebuilt trans. Here are a couple notes:
The advice to keep it in 3rd is paramount. Fuel is cheap compared to trans rebuild.
The factory engine temp gauge is not 100% accurate. Will still read ~200* until around 220* actual temp. Monitor engine temps on grades VIA OBD2. Otherwise, don't fear the RPM.
I just recommended against it in another thread, but for towing a TruCooler 40k is a nice tranny cooler that will replace your factory one with relative ease. For the cost of one on eBay, might be worth installing for the trip and going back to a smaller cooler for regular driving.
You should be fine at 70mph. I think my longest haul with a heavy load behind my Tahoe was Indianapolis to Bristol, VA with around 9,000-10,000#. My Tahoe has 3.73 gears and had 33" tires at the time, I maintained a happy 75 most of the trip. Remember, highway driving is what's easiest on a vehicle. Speed isn't the enemy, lots of shifting is (as mentioned).
Don't go overboard on maintenance before the trip. Oil change, grease the ball joints, make sure you've got gear oil in the rear end - sure. Tranny service is 50/50. Has it been done before? How long? If you have a filter/fluid change done, have them drop the valve body and make sure none of the check balls have beat their way into the separator plate, and put a shift kit in while you're in there and block off the PWM solenoid. Honestly though, if the trans was acting right I probably wouldn't touch it and just make sure it stays cool. Definitely do not have it flushed. Mostly make sure everything is working as it should and if it is don't mess with it just before a trip.
*If* you have a tune done, have them tune out the Torque Converter PWM. That's your #2 weak link that will take out the trans.
T-Rain
