Sas 98 'hoe
R
roy72004
Maiden voyage for it. Took it to a local off-road park. Definitely need to get the gears done.
Sent from my SM-G920V using Tapatalk
R
roy72004
It was a lot of fun. Lost my power steering and snapped some wheel studs... My guess is they worked loose.
R
roy72004
How do you get better parts... Other than going to Dana 80... It's just the studs worked loose on me. I welded everything together today, hub to drum and studs to both. They won't be doing that again.
R
roy72004
I didn't break the pump or gear., I've had horrible luck with pumps. This'll be 4 or 5 pumps in as many years. It has assist still, but only at higher rpms, and most the time. It whines when I'm turning it and giving it a good amount of fuel. It's not a broke shaft.
R
roy72004
I'm going to go full hydraulic once I track down another job... I already bought my pump with the bypass to get me by till it gets full hydraulic steering
TVan
