"Service 4WD" - Master Thread
humer101
NJ,USA
Nop absolutely no they will send someone from Gm ing. Department to check the problem in my truck. Is running good now but 4wd auto or 4H grinding noise is very annoying.
[emoji19]
humer101
NJ,USA
Problem is about 2 weeks after purchase but they keep doing updates, but honestly I don't think that will solve the problem. Grinding noise is only in auto or 4h, 2wd runs beautiful. Where I live I need 4wd because snow and ice.
[emoji19]
Tahoe14
Central Fl
So if I am reading your work order correctly they were not able to duplicate the 4wd issue. The GM rep was not able to give you a difinitive answer about fixing or replacing your vehicle and now a GM engineer is coming. Wow, I sure hope they get this resolved for you. As the saga continues. We will all be standing by for this one. Good luck.
humer101
NJ,USA
Yepp they will check deep on this or they have to may replace whole transfer case. Who knows I will take anything I just want get this fixed. But the truck runs beautiful in 2wd problem start after you switch to auto or 4h.and now is snow and ice all over. I really need 4wd to works right without any noises.
[emoji165] [emoji19]
kcb14214
Yeah Westchester is in the 20" band. Told the wife 50 times put it back in 2wd before you shut it off..
Mclifton43
