service history from vin#?
doubletapdrew
I like to see the work reports on it if u can VIN 1GTHK29607E537125 :emotions133:
Vehicle Information
VIN: 1GTHK29607E537125 Model: TK20753-2007 SIERRA 2500HD 4WD EXT CAB
Service Contract: No Branded Title: No Warranty Block: No PDI Status: No
Order Type: 60 - RETAIL - SOLD
Field Actions: 0 Open
Required Field Actions Open field actions are highlighted
Type Number Original Nbr Description Release Date Status
Product Safety Recall N080048 08048 HEATED WINDSHIELD WASHER MODULE SHORT CIRCUIT - ADD WIRE HARNESS 08/28/2008 Closed
Customer Satisfaction Program N080142 08142 ECM EEPROM - REPROGRAM ECM 05/12/2008 Closed
Product Safety Recall N090270 09270 SDM RETAINING MOISTURE 10/19/2009 Closed
Product Safety Recall N100153 10153 HEATED WINDSHIELD WASHER MODULE SHORT CIRCUIT - DISABLE AND REMOVE MODULE 06/08/2010 Closed
Branded Title
*The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Vehicle has no current record of branded titles.
Warranty Block
Vehicle has no current record of warranty block.
Service Information
Vehicle has no current record of outstanding service information.
OnStar and XM Satellite Radio Information
Refer to Help page for details. For OnStar contact 888.ON.STAR1 (888.667.8271) and for XM Radio contact 877.GET.XMST (877.438.9677 Canada) and in the USA:800-556-3600.
OnStar Equipped: Y OnStar Status: Inactive
XM Equipped: Y XM Radio ID: HV1UT08W XM Status: Active
OnStar Vehicle Diagnostics: N DMN Enabled: N
Applicable Warranties Valid warranties are highlighted
Valid Description Start Date Effective Odometer End Date End Odometer
Emission Limited Warranty 09/17/2007 265 KM 09/17/2012 80,265 KM
New Vehicle Limited Warranty 09/17/2007 265 KM 09/17/2010 60,265 KM
Powertrain Limited Warranty 09/17/2007 265 KM 09/17/2012 160,265 KM
Corrosion Limited Warranty 09/17/2007 265 KM 09/17/2013 160,265 KM
Diesel Engine Limited Warranty 09/17/2007 265 KM 09/17/2012 160,265 KM
Service Contract
Vehicle has no current record of service contracts.
Transaction History View Details
Job Card Date Job Card Number Transaction Type Transaction Adjustment Labour Operation Odometer Reading
11/29/2011 56415 ZFAT----Field Action Recall Partial Debit V2281 - 10153-Windshield Washer Solvent Heater Asm Removal and Issue Check to Customer (Cust. Vehicles Only) 175,154 KM
11/29/2011 56415 ZFAT----Field Action Recall Full Debit - Reversal V2281 - 10153-Windshield Washer Solvent Heater Asm Removal and Issue Check to Customer (Cust. Vehicles Only) 175,154 KM
11/29/2011 56415 ZFAT----Field Action Recall V2281 - 10153-Windshield Washer Solvent Heater Asm Removal and Issue Check to Customer (Cust. Vehicles Only) 175,154 KM
05/31/2010 33593 ZFAT----Field Action Recall V2142 - 09270 - Remove Acoustical Pad from the SDM Area 101,762 KM
05/06/2009 294048 ZFAT----Field Action Recall V1993 - 08048A - Jumper Harness Installation 54,838 KM
05/06/2009 294048 ZFAT----Field Action Recall V1819 - 08142 ECM EEPROM - Reprogram ECM 54,838 KM
03/19/2007 A37125 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 KM
---------- Post added at 09:02 AM ---------- Previous post was at 09:00 AM ----------
Drew, looking for service records on possible Escalade ESV purchase. VIN 1GYS4HEF9BR147404. Thanks.
Vehicle Information
VIN: 1GYS4HEF9BR147404 Model: 6K10906-2011 ESCALADE ESV AWD
Service Contract: No Branded Title: No Warranty Block: No PDI Status: Yes
Order Type: 70 - RETAIL - STOCK
Customer Satisfaction Program N120138 12138 TRANSMISSION DIPSTICK TUBE FRACTURE 10/24/2012 Closed
Branded Title
Warranty Block
Service Information
XM Equipped: Y XM Radio ID: BCNT82MT XM Status: Active
Special Coverage 11273 12/22/2010 60 MI 12/22/2020 120,060 MI
Premium Care Maintenance 12/22/2010 60 MI 12/22/2014 50,060 MI
Corrosion Limited Warranty 12/22/2010 60 MI 12/22/2016 Unlimited
Emission Limited Warranty 12/22/2010 60 MI 12/22/2013 50,060 MI
Emission Select Component Ltd Wty 12/22/2010 60 MI 12/22/2018 80,060 MI
Emission Select State Component Lty Wty 12/22/2010 60 MI 12/22/2017 70,060 MI
Powertrain Limited Warranty 12/22/2010 60 MI 12/22/2015 100,060 MI
Bumper to Bumper Limited Warranty 12/22/2010 60 MI 12/22/2014 50,060 MI
Service Contract
05/07/2014 292135 ZREG----Regular Vehicle Transaction 0600202 - ROADSIDE SERVICE (FLAT TIRE) 64,984 MI
05/07/2014 292135 ZREG----Regular Vehicle Transaction 0600002 - CADILLAC-COST OF TECH. TO MAKE ROADSIDE SRVC CALLS 64,984 MI
02/17/2014 287460 ZREG----Regular Vehicle Transaction T5876 - 11273 - Throttle Position Sensor Cover Replacement and ECM Reprogram (inc diagnosis) 60,956 MI
10/16/2013 280798 ZREG----Regular Vehicle Transaction 0600202 - ROADSIDE SERVICE (FLAT TIRE) 54,335 MI
10/15/2013 0012946332 ZREG----Regular Vehicle Transaction 0600072 - ROADSIDE SERVICE (PREMIUM) 54,335 MI
05/23/2013 272057 ZREG----Regular Vehicle Transaction 0600014 - Non-Warrantable Vehicle Modifications and/or Suspected Vehicle Tampering 46,857 MI
05/23/2013 272057 ZREG----Regular Vehicle Transaction 0600513 - Cadillac Premium Care - Tire Rotation 46,857 MI
05/23/2013 272057 ZREG----Regular Vehicle Transaction 0600503 - Cadillac Premium Care - Oil Change 46,857 MI
01/07/2013 263614 ZREG----Regular Vehicle Transaction Z2263 - Cadillac Premium Care - Tire Rotation 39,725 MI
01/07/2013 263614 ZREG----Regular Vehicle Transaction Z2262 - Cadillac Premium Care - Oil Change 39,725 MI
01/07/2013 263614 ZFAT----Field Action Recall V2644 - 12138 - Install Transmission Filler Tube Damper 39,725 MI
01/07/2013 263614 ZREG----Regular Vehicle Transaction E9475 - Wheel, Bead Seat Repair 39,725 MI
08/16/2012 255328 ZREG----Regular Vehicle Transaction Z2265 - Cadillac Premium Care - Engine Air Filter 31,423 MI
08/16/2012 255328 ZREG----Regular Vehicle Transaction N9999 - Electrical Controls - Labor Only - Detailed Comment Required 31,423 MI
08/16/2012 255328 ZREG----Regular Vehicle Transaction Z2263 - Cadillac Premium Care - Tire Rotation 31,423 MI
08/16/2012 255328 ZREG----Regular Vehicle Transaction Z2262 - Cadillac Premium Care - Oil Change 31,423 MI
03/27/2012 247569 ZREG----Regular Vehicle Transaction J9991 - Customer Concern Not Duplicated (CCND) - Engine Concern 22,858 MI
03/27/2012 247569 ZREG----Regular Vehicle Transaction Z2263 - Cadillac Premium Care - Tire Rotation 22,858 MI
03/27/2012 247569 ZREG----Regular Vehicle Transaction Z2262 - Cadillac Premium Care - Oil Change 22,858 MI
11/15/2011 239988 ZREG----Regular Vehicle Transaction B0342 - Front Tow Hook Replacement 15,895 MI
11/15/2011 239988 ZREG----Regular Vehicle Transaction Z2263 - Cadillac Premium Care - Tire Rotation 15,895 MI
11/15/2011 239988 ZREG----Regular Vehicle Transaction Z2262 - Cadillac Premium Care - Oil Change 15,895 MI
06/06/2011 230564 ZREG----Regular Vehicle Transaction H9991 - Customer Concern Not Duplicated (CCND) - Brakes 7,674 MI
06/06/2011 230564 ZREG----Regular Vehicle Transaction Z2262 - Cadillac Premium Care - Oil Change 7,674 MI
06/06/2011 230564 ZREG----Regular Vehicle Transaction Z2263 - Cadillac Premium Care - Tire Rotation 7,674 MI
02/21/2011 224408 ZREG----Regular Vehicle Transaction E0203 - Tire and Wheel Balancing - Four 1,415 MI
02/21/2011 224408 ZREG----Regular Vehicle Transaction J9991 - Customer Concern Not Duplicated (CCND) - Engine Concern 1,415 MI
02/21/2011 224408 ZREG----Regular Vehicle Transaction D9995 - Customer Concern Not Duplicated 1,415 MI
09/04/2010 A47404 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 1 MI
doubletapdrew
Vehicle Information
Branded Title
Warranty Block
Service Information
Service Contract
---------- Post added at 08:39 AM ---------- Previous post was at 08:38 AM ----------
Vehicle Information
Branded Title
Warranty Block
Service Information
Service Contract
rbnzrcn
Drew, last vehicle got sold before I could get to it. How about this one: 1GYS4HEF8BR152352
Thanks.
doubletapdrew
Hi Drew, would you be able to run mine? Thanks so much!
1GKFK130X7J286650
Vehicle Information
VIN: 1GKFK130X7J286650 Model: TK10706-2007 YUKON 1500 4WD
Field Actions: 1 Open
Service Update Bulletins N070033 07033 SERVICE UPDATE - INVENTORY & CUST. VEHS-BATTERY RUNDOWN-*EXP W/BASE WARRANTY* 02/06/2007 Open
Branded Title
Warranty Block
Service Information
OnStar Equipped: Y OnStar Status: Active
XM Equipped: Y XM Radio ID: 9EC9Q04M XM Status: Active
OnStar Vehicle Diagnostics: Y DMN Enabled: Y
Emission Select Component Ltd Wty 11/20/2006 17 MI 11/20/2014 80,017 MI
Corrosion Limited Warranty 11/20/2006 17 MI 11/20/2012 100,017 MI
Bumper to Bumper Limited Warranty 11/20/2006 17 MI 11/20/2009 36,017 MI
Powertrain Limited Warranty 11/20/2006 17 MI 11/20/2011 100,017 MI
Service Contract
09/07/2010 428411 ZFAT----Field Action Recall V2281 - 10153-Windshield Washer Solvent Heater Asm Removal and Issue Check to Customer (Cust. Vehicles Only) 77,360 MI
11/20/2008 391739 ZREG----Regular Vehicle Transaction B2945 - Skid Strips, Luggage Rack - Replace 45,932 MI
11/20/2008 391739 ZREG----Regular Vehicle Transaction C7343 - Heating Element, Left Front Seat Back - Replace 45,932 MI
11/20/2008 391739 ZFAT----Field Action Recall V1993 - 08048A - Jumper Harness Installation 45,932 MI
06/22/2008 V92219 ZREG----Regular Vehicle Transaction Z2084 - ROADSIDE SERVICE (FLAT TIRE) 33,000 MI
06/05/2008 381237 ZREG----Regular Vehicle Transaction Z7911 - 2-WAY SHUTTLE COURTESY TRANSPORTATION 34,692 MI
04/19/2008 U80498 ZREG----Regular Vehicle Transaction Z2084 - ROADSIDE SERVICE (FLAT TIRE) 15,000 MI
11/09/2006 A86650 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
---------- Post added at 11:34 AM ---------- Previous post was at 11:30 AM ----------
Thanks.
That one didn't pull up a record:
Investigate Vehicle History
This screen allows IVH users to obtain service and related information on an individual VIN.
A record was not found for the information you entered
Please enter the following fields * Indicates required field
* Enter full VIN or last 8 digits of VIN Enter an odometer reading for this vehicle
doubletapdrew
Thanks.
Vehicle Information
VIN: 1GYS4HEF8BR152352 Model: 6K10906-2011 ESCALADE ESV AWD
Customer Satisfaction Program N120138 12138 TRANSMISSION DIPSTICK TUBE FRACTURE 10/24/2012 Open
Branded Title
Warranty Block
Service Information
XM Equipped: Y XM Radio ID: Q2KR82WN XM Status: Active
Special Coverage 11273 12/09/2010 6 MI 12/09/2020 120,006 MI
Premium Care Maintenance 12/09/2010 6 MI 12/09/2014 50,006 MI
Corrosion Limited Warranty 12/09/2010 6 MI 12/09/2016 Unlimited
Emission Limited Warranty 12/09/2010 6 MI 12/09/2013 50,006 MI
Emission Select Component Ltd Wty 12/09/2010 6 MI 12/09/2018 80,006 MI
Emission Select State Component Lty Wty 12/09/2010 6 MI 12/09/2017 70,006 MI
Powertrain Limited Warranty 12/09/2010 6 MI 12/09/2015 100,006 MI
Bumper to Bumper Limited Warranty 12/09/2010 6 MI 12/09/2014 50,006 MI
Service Contract
02/18/2014 221718 ZREG----Regular Vehicle Transaction 0600513 - Cadillac Premium Care - Tire Rotation 45,772 MI
02/18/2014 221718 ZREG----Regular Vehicle Transaction 0600503 - Cadillac Premium Care - Oil Change 45,772 MI
02/18/2014 221718 ZREG----Regular Vehicle Transaction T5876 - 11273 - Throttle Position Sensor Cover Replacement and ECM Reprogram (inc diagnosis) 45,772 MI
05/31/2013 306904 ZREG----Regular Vehicle Transaction 0600202 - ROADSIDE SERVICE (FLAT TIRE) 33,570 MI
05/31/2013 306904 ZREG----Regular Vehicle Transaction 0600002 - CADILLAC-COST OF TECH. TO MAKE ROADSIDE SRVC CALLS 33,570 MI
05/28/2013 0010726244 ZREG----Regular Vehicle Transaction 0600072 - ROADSIDE SERVICE (PREMIUM) 33,570 MI
05/03/2013 0880606 ZREG----Regular Vehicle Transaction 0600428 - NAVIGATION RADIO RECEIVER-RETURN TO AC/DELCO ESC 32,978 MI
05/02/2013 213210 ZREG----Regular Vehicle Transaction 3420840 - Radio Replacement 32,978 MI
05/02/2013 213210 ZREG----Regular Vehicle Transaction 4062391 - Valve Lifter Replacement - Both Sides 32,978 MI
01/22/2013 210180 ZREG----Regular Vehicle Transaction N9996 - Customer Concern Not Duplicated (CCND) - Entertainment/Radio/Navigation/USB/Bluetooth 28,233 MI
01/22/2013 210180 ZREG----Regular Vehicle Transaction Z2265 - Cadillac Premium Care - Engine Air Filter 28,233 MI
01/22/2013 210180 ZREG----Regular Vehicle Transaction Z2263 - Cadillac Premium Care - Tire Rotation 28,233 MI
01/22/2013 210180 ZREG----Regular Vehicle Transaction Z2262 - Cadillac Premium Care - Oil Change 28,233 MI
07/24/2012 204945 ZREG----Regular Vehicle Transaction Z2262 - Cadillac Premium Care - Oil Change 20,569 MI
01/19/2012 199519 ZREG----Regular Vehicle Transaction Z2263 - Cadillac Premium Care - Tire Rotation 12,979 MI
01/19/2012 199519 ZREG----Regular Vehicle Transaction E9475 - Wheel, Bead Seat Repair 12,979 MI
01/19/2012 199519 ZREG----Regular Vehicle Transaction Z2262 - Cadillac Premium Care - Oil Change 12,979 MI
11/14/2011 197559 ZREG----Regular Vehicle Transaction R0759 - Radio Reprogramming with SPS 11,162 MI
06/14/2011 192983 ZREG----Regular Vehicle Transaction Z2263 - Cadillac Premium Care - Tire Rotation 6,193 MI
06/14/2011 192983 ZREG----Regular Vehicle Transaction Z2262 - Cadillac Premium Care - Oil Change 6,193 MI
09/12/2010 A52352 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 1 MI
For this vehicle:
→ View Vehicle Summary
→ Service Contract
→ Branded Title
→ Warranty Block
→ View Vehicle Build
→ View Vehicle Component Summary
→ View Vehicle Transaction History Detail
→ View Vehicle Delivery Information
→ Investigate Major Assembly History
doubletapdrew
how about any information for vin# 1GKFK66878J140383
Thanks in Advance
Vehicle Information
VIN: 1GKFK66878J140383 Model: TK10906-2008 YUKON XL 1/2 TON - 4WD
Service Update Bulletins N070338 07338 SUB-COLD START P1400 OBD SYST IMPROVEMENT-REPROGRAM ECM-EXPIRES JAN. 31, 2009 12/21/2007 Closed
Branded Title
Warranty Block
Service Information
XM Equipped: Y XM Radio ID: AG6DW0MJ XM Status: Active
OnStar Vehicle Diagnostics: Y DMN Enabled: N
Corrosion Limited Warranty 09/30/2008 247 MI 09/30/2014 100,247 MI
Bumper to Bumper Limited Warranty 09/30/2008 247 MI 09/30/2011 36,247 MI
Emission Select Component Ltd Wty 09/30/2008 247 MI 09/30/2016 80,247 MI
Special Coverage 11273 09/30/2008 247 MI 09/30/2018 120,247 MI
Powertrain Limited Warranty 09/30/2008 247 MI 09/30/2013 100,247 MI
Service Contract
05/09/2012 171052 ZFAT----Field Action Recall V2281 - 10153-Windshield Washer Solvent Heater Asm Removal and Issue Check to Customer (Cust. Vehicles Only) 94,575 MI
11/19/2008 133539 ZFAT----Field Action Recall V1993 - 08048A - Jumper Harness Installation 3,263 MI
10/02/2008 132113 ZFAT----Field Action Recall V1779 - 07338 Reprogram Engine Control Module (ECM) 25 MI
10/02/2008 132113 ZREG----Regular Vehicle Transaction T5716 - 08048 - Remove Heated Windshield Washer 60 Amp Fuse 25 MI
10/01/2007 A40383 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
Jhawk79
